fuel injector upgrade?
Old Jun 14, 2014 | 09:20 AM
BrandonStebing's Avatar
Default fuel injector upgrade?
back again, but before I ask a bunch of questions again, I would just like to thank everyone on her for all their help and tips and advice! when ever I cant figure out something on my own I post on here and less than 2 hours later I will have a couple responses and they are all heavily detailed.
Ive been saving some money for the "project monte fund" and I was planning on getting some wheels, well my 400 turned into 600$ and in a week it will be about 800$. so ive been thinking my car looks good on my stock wheels so why don't I upgrade my engine a bit. im looking to add the most power while spending the least money, I guess that's everyone goal. I was thinking about upgrading my fuel injectors to some 42# injectors, but after looking at zzp and their prices, for 5$ more I can get some 60# injectors. I currently have a magnalow dp and cat and full 2.5 exhaust, and a short ram intake. so what should I upgrade to get me some more power? I also plan on getting a zzp tune when im done so that alone will open up some power. not sure what to do next some one help. I plan on eventually doing a turbo build, so im looking to upgrade everything before I get the tubro.
Old Jun 14, 2014 | 10:10 AM
gasman's Avatar
well just because you get bigger fuel injectors don't mean you get more hp. all it means is you will just dump more fuel into your engine for no reason. you would still have to re program your ecu to ajust for the added fuel really.
Old Jun 14, 2014 | 01:04 PM
turbo monte's Avatar
Upgraded fuel injectors are useless unless you have more air flow (boost) there is a suck thing as to big of am injector. If injector is too big and needs scaled back too much the injector goes static and does not fuel consistant. Only get injectors once your turboed
Old Jun 14, 2014 | 03:33 PM
ohara's Avatar
Best bang for the bucks would be
Er ratio rockers
HV3 insert
PCM tuned
You already have the downpipe and cat so that is a plus as well as your CAI intake.
This is about as far as I would take it as you are planning to eventually get the turbo, which in all reality will be your best performance addition
Old Jun 14, 2014 | 07:33 PM
zipper's Avatar
Bigger fuel injectors don't increase performance, they simply give you the fuel that's needed. If you convert to e85, then sure, upgrade your injectors. But if you're only an NA 3800 you will never need the injectors until you go with boost or nitrous. Not only that, but you can find 42# injectors much cheaper on clubgp, grandprixforums.net, or here on MCF in the classifieds. I bought 8 42# injectors on clubgp back in the day for $115.
There's a good thread on MCF in the engine forum that gives a good outline on what to do to our engines and when. Before you spend money do some home work and shop around. ZZP is a great company, but you can find parts all over the internet.
Old Jun 15, 2014 | 07:41 PM
X3. Skip the injectors until they are needed. It's an easy job.
Old Jul 26, 2014 | 10:26 PM
Er ratio rockers
HV3 insert
PCM tuned
does anyone make aftermarket rocker arms, that CAN be used with an aftermarket cam. i plan to cam my car in the near future before the turbo install
Old Jul 26, 2014 | 11:04 PM
nitehawkjcb's Avatar
You can get them, but you need either 1.6 or 1.7 rockers depending which cam you go with IIRC.
Old Jul 26, 2014 | 11:08 PM
I'm running a stage 5 turbo cam with 1.6 yella terra roller rockers. (Yella terra discontinued the 1.6 ratio) could get Harland sharps though.
Old Jul 27, 2014 | 08:53 AM
arent 1.6 ratio the same as stock? what performance gains do you get from the yella terra 1.7?
