a few questions
Old Mar 26, 2008 | 11:55 PM
kennethmoore77's Avatar
Default a few questions
ok ive got an 01 ss and i will be putting a supercharger on it. but have a few questions.
1. will any 3800 series II sc work on this car reguardless as to what its off of?
2. will i have to get new computer or mine flashed or will stock computer handle stock boost?
3. what is avereage junkyard price for this unit?
Old Mar 27, 2008 | 10:13 PM
Default RE: a few questions
ORIGINAL: kennethmoore77
Yes- they are all a gen 3 M90. Obviously you're gonna need the LIM, TB, heads, balancer, injectors, fuel rails, etc etc- but you probably already knew that. Here's a link to the list of all the parts you need in case you didn't know:
http://www.wbodystore.com/grandprix/...kit-p-157.html
You can have your pcm flashed. You have to get the L67 MAP sensor- and that is what allows the pcm to see the boost. The new pcm tune also compensates for the new injectors, and the BBV valve among other things.
Just the supercharger or all the parts for a top swap? It seems $900-1100 for parts only (no gaskets/fluids) is about average if you get it all from a vendor.
If you were to buy it piecemeal online (ie clubgp, ebay)- I bet you could get all the parts for $500 or so if you are really patient and wait for good deals. It'll probably take a little bit to collect all the parts if you go this route.
For just the blower alone- that is a huge variable- online I've seen them go as low as $100 and as high as $400 or so for a stock gen 3 M90. It really depends on the condition of the rotor coating, mileage, bearing condition, etc etc.
Junkyards seem to charge much more because they think its some exotic item even though L67s are common as dirt.
Good luck- its a pretty labor intensive swap, especially since you pull everything down to the short block- unless of course you go with zzp's SS kit in which case its still a pretty hefty project.
Old Mar 28, 2008 | 12:22 AM
ParrottZ34's Avatar
I back what bumpin said.
I jsut did ZZP's SS swap, and IMO the swap wasn't too hard, but there is a lot to do. Its definately a worthwhile mod.
I bought my supercahrger on clubgp, already proted and polished for $235, you just have to wait for a good deal to come around like bumpin said, and you could easily do the entire swap for under $500
Old Mar 28, 2008 | 04:49 AM
ok so it seems that if ive found a 3800 seroes II sc compleate sittin in the salvage yard for 500 bucks i should purchase the whole engine insted of just the blower to ensure i get everything i need
skidoo6713
Jan 21, 2008 10:44 PM
Gordon
Mar 1, 2007 08:33 PM
06BlackSS
Jan 11, 2007 08:55 PM
72MonteCarlo
Mar 3, 2006 09:53 AM
kissmyss03
Jun 30, 2005 12:18 PM
