F-Body brake upgrade
Alright people i found a pretty good deal on some F-Body calipers, brackets, lines and pretty much everything i need. Who has a list of everything i need or just some stuff i need to know before doing the upgrade. My car is due for a brake job so i figured why not. Any help would be appreciated
If I'm not mistaking the braclet will need to be drilled so the bolts fit through the f-body bracket (monte bolts are a m14 and f-body bolts are a m12.
Some reading material I found for you
http://www.grandprixforums.net/threa...d-Brake-Thread
http://www.regalgs.org/topic/54303-f...brake-upgrade/
The Camaro setup is two piston..
