F-Body brake upgrade
Old Oct 1, 2015 | 08:02 PM
Brendocee55's Avatar
Default F-Body brake upgrade
Alright people i found a pretty good deal on some F-Body calipers, brackets, lines and pretty much everything i need. Who has a list of everything i need or just some stuff i need to know before doing the upgrade. My car is due for a brake job so i figured why not. Any help would be appreciated
Old Oct 1, 2015 | 08:07 PM
The car is a 98 and pretty sure the Camaro's are all the same from 98-02, or does it have to be a 2000-2002?
Old Oct 1, 2015 | 10:11 PM
turbo monte's Avatar
If I'm not mistaking the braclet will need to be drilled so the bolts fit through the f-body bracket (monte bolts are a m14 and f-body bolts are a m12.
Some reading material I found for you
http://www.grandprixforums.net/threa...d-Brake-Thread
http://www.regalgs.org/topic/54303-f...brake-upgrade/
Old Oct 2, 2015 | 08:37 PM
Thank you, i will look into those!
Old Oct 3, 2015 | 11:51 PM
the top pad is stock 2005 monte carlo SS , Bottom pad is stock 2002 Camaro.. I flipped the bracket at the steel line it gave me a little more hose going to the caliper..
Old Oct 4, 2015 | 08:42 AM
Hiroska's Avatar
Jerry I assume this will also work for the 7th gen? Those calipers look much bigger than our two Pistons in front, does the back also swap out as well?
Old Oct 4, 2015 | 10:57 AM
Iam not sure if this is any bigger then your two piston setup.
The Camaro setup is two piston..
