ENGINE SWAP IN A 87 M/C
Old Jan 25, 2008 | 08:25 PM
TAZ454's Avatar
Default ENGINE SWAP IN A 87 M/C
Which GM 350 crate motor would be the best bet for replacing my 305 in my stock 87 LS , Will all of the brackets, smog stuff, intake & exhaust manifolds fit. It will have to go thru emmisions . Would a 250hp or the 290hp GM be best ? Someone told me that there were some problems with the 290hp motor???
Old Jan 25, 2008 | 09:42 PM
TAZ454's Avatar
Default RE: ENGINE SWAP IN A 87 M/C
Old Jan 26, 2008 | 08:13 AM
88ss408's Avatar
any motor will fit in no prob because they are all small block chevy's
if you are not looking for monster power and just a good working motor i would get a gm 350 short block and take everythinng off the 305 or even get the gm350 long block and just swap intake and pully's
if your town does smog testing the 350 should pass it with all the stock emission stuff
Old Jan 26, 2008 | 10:10 AM
TAZ454's Avatar
If I decide to build a 350 , What cam & heads would be best for the 350, that would work with the cpu and carb, and pass smog . Would any year 350 block work , I noticed some shops on ebay selling 350's but adding a note thattheyare for certian yearcars ,Iwant a little more power than the stock 305 but just a dirver, long trips no racing ,
Old Jan 26, 2008 | 02:51 PM
mickey's Avatar
i think if it was me any more it is cheaper to do the long block and or a creat motor. I would do the 355. stroker and enjoy it knowing that you have a warrenty also.
Old Jan 26, 2008 | 05:06 PM
88ss408's Avatar
if you just want a good driver i would get a factory replacement long block from your local part store
everything is there except oil pan,valve covers,pully set up and intake,carb but you got all that stuff off your old motor just have to clean it up and put it on
i got one not to long ago for aguy's truck and it was around the 1900$ mark
or you can alwayz rebuilt your 305 with a stroker kit for like 1200$ (i think) plus machine work a sumit raceing cam 2020/2030/2040 cam work good in them
Old Feb 6, 2008 | 02:17 PM
Wyotech's Avatar
I am new here but when i did my engine swap from the 305 i went to Jegs and got the 330hp 350 long block from GM Performance Parts. It comes with a warrenty and just slipped right in and give me pretty decent power. Also this motor has four bolt mains so more strengh for add ons.
Old Mar 11, 2008 | 07:58 AM
samckitt's Avatar
ORIGINAL: mickey
355 stroker? A 355 is just a .030" bored 350 block, same crank stroke of 3.48" I would definetly go 350 over rebuilding the 305. Most of the parts are the same, or similar. 350 is used more, might be a little cheaper.
Budsjlm
Apr 3, 2012 05:43 PM
HaRvArDaLe
Nov 3, 2006 08:00 AM
goat
Feb 19, 2006 11:58 PM
batman
Feb 16, 2006 03:18 AM
rchurch
Apr 29, 2005 05:49 PM
