Engine Swap?
Old May 28, 2007 | 11:45 AM
Nickky T's Avatar
Default Engine Swap?
Any one know if a 95' Z34 3.4 will fit in a 96' Z34 3.4? Any info will help thanx.
Old May 28, 2007 | 05:19 PM
scc24540's Avatar
Default RE: Engine Swap?
yessir i belive it will, most all the 95-99 monte are completely interchangeable, u might hafta keep ur old intake and exhaust but all in all they are duplicate engines
Old May 28, 2007 | 07:39 PM
z34phoenix's Avatar
that is incorrect! they are not duplicate engines... there is infact many internal differences between the 95 and 96 3.4 L DOHC engines.
-intake and TB are the most visible diff's
-heads are different
-pistons are diff
-cams are diff
-computer and OBD systems are diff
-exhaust manifolds are diff
-many sensors are also diff.
Now my question is why do you want to swap to a 95motor? the 96 and 97 DOHC are the best ones. 95 is the worst DOHC in the entire history for the LQ1 motor. the computer is not able to be tuned like the 96-97 and you cant swap eprom chips like the 91-94's
For you to run the 95 motor you would need the computer, complete wire harness, exhaust manifolds and all the engine sensors and parts. Personally i would stick with the 96 or if i was to go thru all that work i would put in a 97 motor and trany... they are the best pair! the trany was stronger and the engine had all the bugs worked out and was a wonderful engine...
further more if you wree to dive in and do that much work you might as well change to the 3800 SC motor and call it a day. if power is what you want that motor will make much more power then you can pull out of our DOHC. i have been very luckey and have some nice #'s with my Z but i have put a lot of work into it. a stock l67 (3800 SC) would be dead even in the 1/4 most likely and i wouldnt stand a chance off the line aganst one.
Old May 29, 2007 | 06:48 AM
Nickky T's Avatar
I want to swap engines because i found a 95' Z34 on ebay with no miles and never been run in a car. I was given to a college by gm for them to look at and now he is puting it up fot sale. But i guess if it is not a good motor then it is not worth getting it, so thanx for the info.
Old May 29, 2007 | 07:09 AM
wiz kidd's Avatar
how much is it?? an egine with no miles would be good any time
Old May 29, 2007 | 06:37 PM
mickey's Avatar
like he said it is internal changes i belive the externals on the them were real close but you might need to get the brain out of a 96 to make it work
Old May 29, 2007 | 06:55 PM
z34phoenix's Avatar
to use that 95 block its a lot of work... its possible to swap sensors to use your 96 computer and harness.... but to use your exhaust manifolds you would need the 96 heads.
Old May 29, 2007 | 07:43 PM
benhillzone3's Avatar
sounds like a real headache in the making ot me
Old May 29, 2007 | 08:21 PM
mickey's Avatar
or change the manifolds with the motor.
but to me i dont think it will be a headach . just make sure you know all ya can before you do it.
Budsjlm
Apr 3, 2012 05:43 PM
HaRvArDaLe
Nov 3, 2006 08:00 AM
goat
Feb 19, 2006 11:58 PM
batman
Feb 16, 2006 03:18 AM
rchurch
Apr 29, 2005 05:49 PM
