Engine Shuts off while driving
Old Dec 15, 2020 | 10:51 AM
2000MCdailydriver's Avatar
Default Thank you!
I think there is a fuel pressure regulator that causes the explosions on the 6th Gen Monte Carlo with 3800 motor you might want to check that.
I will check that out!!
update: and started a new thread: found two vac leaks- throttle body gasket! Used a cigarette to do a “smoke test” and it sucked the smoke in there! Also small cracks to vac lines/harness from fuel regulator to evap emi. Runs solid now- no more dying while driving, no more coughing at high speeds, but still dies at idle when warm.
Old Dec 15, 2020 | 02:28 PM
Did you fix the tbody gasket?
montecowlo
Dec 1, 2014 10:23 AM
LuLuBella26
Sep 17, 2013 05:06 PM
kody02ss
Dec 28, 2011 12:01 AM
heartbeat
Mar 18, 2011 01:36 PM
zyon555
25
Jan 13, 2011 07:01 AM
