6th Gen ('00-'05): Engine pull
Old Aug 23, 2019 | 11:39 AM
03vaderSS's Avatar
Default Engine pull
Hey guys so I’m about ready to pull the engine. A buddy of mine reccomends we put 4 supercharger bolts back into the intake manifold and pull it that way, like an old Chevy motor that’s carbureted, since most of the accessories will be off. I have aftermarket heads so I don’t have the hooks and I also have headers. Will this work? Any suggestions? Thanks in advance
Old Aug 23, 2019 | 04:23 PM
Not knowing the size of those bolts off the top of my head. I wouldn't try it.
If you threw your lift brackets away, they should be practically free from a JY or actually free from a local member. Otherwise I'd stick some bolts in the end of tbr block or heads and pull it that way - much more substantial bolt bosses there
You'll likely have to pull the headers anyways depending which kind they are - many of them extend too far down under the firewall and make it harder to pull out.
Old Aug 23, 2019 | 08:56 PM
03vaderSS's Avatar
I have stage 3 zzp heads and 1-7/8 huge zzp headers so I don’t want to mar those up I’m going to remove them first. I don’t have lift brackets. Maybe I could rather strap 2 straps around the block, 1 on each side
Old Aug 24, 2019 | 07:26 AM
Having just looked at those bolts, I wouldnt trust them to lift the engine.. Just throwing that out there for you..
Old Aug 26, 2019 | 04:10 PM
No local 3800 members or junkyards? Certainly plenty of other creative options, but someone local on one of the boards or FB groups would probably let you borrow them for free (or even just give you a set).
Old Aug 27, 2019 | 09:55 AM
nitehawkjcb's Avatar
Definitely see if you can get those brackets somewhere.
WolvenScout
Jan 31, 2020 01:57 PM
wht02monte
May 6, 2018 07:17 AM
mairj40
Feb 9, 2012 12:02 AM
86_MONTE_CARLO_CL
May 12, 2010 07:24 AM
88montessman
Apr 15, 2009 12:41 AM
