Header bolts..
Old May 4, 2018 | 11:29 AM
Default Header bolts..
So can someone link me to a set of bolts for my headers that are not 6 point, or rather not "hex" or whatever its called..
I wanna use an allen wrench or something.. Something that if I had to get in there right now, it wouldnt be a problem.. Idk, what do you guys with headers use??
Old May 4, 2018 | 04:19 PM
Stock bolts here with no issues. What issue are you having?
Old May 4, 2018 | 07:09 PM
Jeffs02rwdSS's Avatar
Try a local store like Fasten All if there's one in your area they can get you hooked up or I have had good luck at home depot when looking for bolts when I was fixing my Fiero.
Old May 5, 2018 | 06:58 AM
Two things..
They keep coming loose.. I was prepared to tighten them every once in a while during the first month or so but its long past that and they just keep coming loose..
And second, theyre ugly..
I guess I could just bring one into the store and ask for "this size" huh??
Old May 5, 2018 | 07:22 AM
INTENSE Racing: Stage 8 Locking Header Bolt Kit for 3800 Series II/III these are a bit expensive but what your looking for and have a lock to prevent them from backing off. Did a google search and found a bunch of different styles.
Old May 5, 2018 | 07:03 PM
Two things..
Depends what you're more concerned about - looks or ensuring they don't back out.
If looks are more important, ARP does make some nice stainless bolts. Also, like you said, you can go to a Fastenal or something and pick up pretty bolts with various head types. However that's not going to help the backing out problem unless your stock bolts are really worn out.
If your want something with a lock feature, Stage 8 does have bolts with the lock tabs and clips for the 3800. You could also buy drilled bolts for aerospace and safety wire them together. These will ensure the bolts can't back out, but they look busy and awful.
I guess I'm suprsied you're having issues with stock bolts backing out though, are they torqued to spec? What gasket are you running (I'm wondering if it's shrinking and losing tension)? Do your headers have thicker flanges than stock manifolds (thinking less thread engagement / less friction to keep them from backing out)?
Old May 6, 2018 | 07:17 AM
Yea, thats what it is.. Flange is much thicker.. I ordered the ones jeffs recommended tho.. Lets hope for the best.. I think this is my other issue also.. The other day when I tightened them, instantly got better power and my timing is back up.. Fuel mileage seems much better also..
Funny thing is, never heard and ticking or anything.. Just a slight whistle that I thought was the intake..
