Engine Ping (KR)
So at WOT my engine gets the ping. I have no codes, CEL's or anything like that. I did a search through this site and the search turns up nothing- No Results. I really don't care for the search function on this forum. Anyway, I read that engine running hot can cause this- No, engine runs at normal operating temp. Fuel Octane rating low- A 3.8 should run on 87 octane no problem. Gas in my area does have up to 10% ethanol in it. And then there is carbon build up- I have ran some injector cleaner through it just recently and I used some oil de-sludging solvent as well. There is only a problem at WOT. Higher octane gas does help but I haven't used octane rating higher than 91 and I shouldn't have to.
What are the main KR problems with the 3.8?
I have done the UIM/LIM gaskets, temp sensor. t-stat, and cat recently.
Appreciate the help
Appreciate the help
![Smile](https://montecarloforum.com/forum/images/smilies/smile.gif)
KR is normal and common on the 3800, and pretty much any engine- especially in small amounts. How much KR are we talking here?
If your KR is crazy excessive- then you may have an actual problem, but some KR is common on pretty much every 3800 I've seen.
Thanks for all the replies and help.
I do not hear a knock at WOT only the slight pinging. From what Bumpin has said I guess this is normal. The car does have 153k miles on it and I don't think that the previous owner took the best of care of it. So WOT throttle pings are normal? The pings aren't excessive and are only at WOT, I can hear the light pinging when driving the car and I am usually merging onto the highway and I got to get on it to merge. The car also has no mods
Maybe someday...
And I live in Maine. I have stepped up to 89 octane for now and the pings are less noticeable at WOT but are still present.
Again, thanks to all for your replies and insight. I appreciate all your help.
![Frown](https://montecarloforum.com/forum/images/smilies/frown.gif)
I'm pretty sure that it is pinging because of the change when I use a higher octane fuel.
I'm gonna try some octane booster or 91 grade (the highest we have here in Maine that is readily accessible) and see if there is a clear difference.
Do you mean you hear an audible ping? If you're hearing knock, something is seriously wrong.
That is why I said- the only way to tell you have knock/ping- is to scan the pcm. You'll see what is called KR which is the pcm pulling timing to avoid actual knock/ping.
Again- if you hear an audible knock/ping- that is not normal, something is wrong.
What could be wrong? If I accelerate hard I can hear pinging. The best way I can describe the pinging is like if you are driving a manual tranny car and are in a high gear and are going up a hill and instead of downshifting, you just put the pedal to the metal.
