Engine Ping (KR)
Old May 23, 2010 | 01:17 AM
Sliver's Avatar
Default Engine Ping (KR)
So at WOT my engine gets the ping. I have no codes, CEL's or anything like that. I did a search through this site and the search turns up nothing- No Results. I really don't care for the search function on this forum. Anyway, I read that engine running hot can cause this- No, engine runs at normal operating temp. Fuel Octane rating low- A 3.8 should run on 87 octane no problem. Gas in my area does have up to 10% ethanol in it. And then there is carbon build up- I have ran some injector cleaner through it just recently and I used some oil de-sludging solvent as well. There is only a problem at WOT. Higher octane gas does help but I haven't used octane rating higher than 91 and I shouldn't have to.
What are the main KR problems with the 3.8?
I have done the UIM/LIM gaskets, temp sensor. t-stat, and cat recently.
Appreciate the help
Old May 23, 2010 | 08:45 AM
Do you mean you hear an audible ping? If you're hearing knock, something is seriously wrong.
KR is normal and common on the 3800, and pretty much any engine- especially in small amounts. How much KR are we talking here?
KR will not throw a code.
Yes, it will run on 87 fine, but that doesn't mean there won't be a little KR at WOT. Could be due to age- a little overly aggressive timing for your area- but a little KR is no big deal, especially on a stock engine.
You're not going to get rid of carbon buildup with that kind of stuff- the worst carbon buildup for KR is in the combustion chamber- and nothing is going to clean off the pistons or inside the chamber.
That's the only time you should have KR- WOT, and other very heavy load situations (ie steep hills, etc)
As the engine ages- you may need to go up a step in octane of fuel to get the same performance and no knock due to carbon build up and a bunch of other things caused by wear and age.
If your KR is crazy excessive- then you may have an actual problem, but some KR is common on pretty much every 3800 I've seen.
No real problems caused by it- other than slight loss of performance- especially on a NA 3800. Now if you had a modded supercharged 3800- it would be different, then KR could chip away the pistons- but on an NA 3800, or stockish SC 3800- KR is no big deal.
Old May 23, 2010 | 09:51 AM
jimbo7's Avatar
how are you finding out that you do have knock?
Old May 23, 2010 | 12:41 PM
zipper's Avatar
Just out of curiousity, where are you from?
Old May 23, 2010 | 11:21 PM
Sliver's Avatar
Thanks for all the replies and help.
I do not hear a knock at WOT only the slight pinging. From what Bumpin has said I guess this is normal. The car does have 153k miles on it and I don't think that the previous owner took the best of care of it. So WOT throttle pings are normal? The pings aren't excessive and are only at WOT, I can hear the light pinging when driving the car and I am usually merging onto the highway and I got to get on it to merge. The car also has no mods Maybe someday...
And I live in Maine. I have stepped up to 89 octane for now and the pings are less noticeable at WOT but are still present.
Again, thanks to all for your replies and insight. I appreciate all your help.
Old May 23, 2010 | 11:38 PM
nitehawkjcb's Avatar
I've never heard any kind of KR and I had 9* of it at one point. Still, no audible pinging noise. Perhaps you have something loose under the hood?
Old May 23, 2010 | 11:41 PM
Sliver's Avatar
I'm pretty sure that it is pinging because of the change when I use a higher octane fuel.
I'm gonna try some octane booster or 91 grade (the highest we have here in Maine that is readily accessible) and see if there is a clear difference.
Old May 24, 2010 | 02:07 PM
Don't waste your money with octane booster, it's a rip off. Just get the highest octane you can.
Old May 24, 2010 | 08:34 PM
huh?
By knock- I meant knock/ping- you shouldn't hear anything from traditional knock/ping unless something is seriously wrong. The engine has knock sensors, and the pcm pulls timing before you ever hear it.
That is why I said- the only way to tell you have knock/ping- is to scan the pcm. You'll see what is called KR which is the pcm pulling timing to avoid actual knock/ping.
Again- if you hear an audible knock/ping- that is not normal, something is wrong.
Old May 25, 2010 | 01:42 AM
Sliver's Avatar
What could be wrong? If I accelerate hard I can hear pinging. The best way I can describe the pinging is like if you are driving a manual tranny car and are in a high gear and are going up a hill and instead of downshifting, you just put the pedal to the metal.
