Engine fan ?
I know summer is here for me but I turned my car off at 5:30 pm and went to my car at 9:30 pm and popped my hood open and my engine was still warm, shouldn't after that long it be cooled down?
When I drive I don't hear my engine fan on, I am curious if its not working properly?
How do I test my engine fan or make it always be on, like I know it comes on only after it gets so hot supposedly.
any help or similar stories to mine?
I think I will have friends check it out this weekend to be safe too
well turn the car on and let it warm up...u should hear the fan kick in. also what is warm? components in the engine can get hotter than 220 degrees easily. if its warm outside with the sun shinning on the hood and the engine bay acting like an oven, the engine could still b warm hours later
It does sit out like you said, and I can understand it will be hot later,
You think a car cover may be a good idea for me through the summer, I would put it on when it sits in front of work but would like to keep it a little cooler and protect everything from the sun. watch think?
when i test diesel generators at work, we will sometimes have the test cell 100-120F. after running the genset for a couple hours at full load things obviously get pretty hot inside the enclosure. after things get shut down, we will monitor temps inside the enclosure and lots of times the heatsoak is amazingly hot after shutdown. it will stay like that for hours as long as the test cell stays up to temp.
so what you're experiencing, IMO, is normal because your hood in a way insulates your engine and creates the heatsoaking. plus, the sun beating down on a super hot day doesn't help either. a cooler tstat would help in your climate but you will want to be able to turn your cooling fans on at the cooler temp also, and i'm not aware of any device for the 3.5/3.9L that can do that...yet. if anyone does know please speak up!
Have you tried checking the fuses? How high is the temp gauge on the dash going?
Thanks for the tips, good advice
I have notice my temp gauge inside will go from cool to the middle, and no matter when I drive or race, my temp gauge has never gone over halfway...
so is it normal to do this, or may my thermostat need to be replaced?
Isn't halfway 195°? So that's a good thing.
And wouldn't a car cover kind of "hold" in the heat also?
yes turning on AC will kick on the other fan cuz it has to cool the condenser
also, i THINK, but i'm not sure, if your coolant gets above a certain temp both fans will kick on anyways. i know that's the case on other vehicles at least.
5th Gen ('95-'99): Passenger Radiator Fan (Fan #2) Not Turning On
gmartinez93
May 11, 2015 10:45 PM
6th Gen ('00-'05): Fan Squeal/Whine Upon Startup With Fan On
jhbasse
Jan 15, 2013 06:39 PM
Dade Chevy
Jul 8, 2009 05:09 PM
