Engine Fan wont stop
Old Dec 9, 2006 | 11:57 PM
PHILLY SS's Avatar
Default Engine Fan wont stop
I got in the car and started the car. It was about 33 degrees. The car started up fine, then I cut the car off and i heard a winding sound coming from the hood. I ofened the hood and the fan was on. And it was making a loud annoying sound. It stoped once I turned the car back on. After driving about 35 miles I noticed that my temp guage wasnt moving at all. I started watching it closly and I drove another 15 or so miles and the guage didnt move at all.
I have no idea what is going on.
Old Dec 9, 2006 | 11:59 PM
PHILLY SS's Avatar
Default RE: Engine Fan wont stop
I forgot to mention that it is a 2001 Monte SS.
Old Dec 10, 2006 | 02:29 PM
wiz kidd's Avatar
coolant temp sensor, thermostat, and rad fan relay and switch
check all those, i would start with the thermostat and while your doing the thermostat check the coolant temp sensor
Old Dec 10, 2006 | 08:03 PM
2000_BLACK_SS's Avatar
i had the same problem and mine was the thermostat would just get stuck open
Old Dec 10, 2006 | 11:26 PM
z34phoenix's Avatar
the fan turning on at key off means the temp is pretty high. my guess is the temp sensor.
Old Dec 12, 2006 | 07:59 PM
PHILLY SS's Avatar
Well after driving the car for a couple days, the temp guage works now, also the fan stoped coming on and off at will. Could that be a lesser of an issue or should I get that looked at. Where is the temp sensor located. I am no mechnic however I am very well mechnically enclined. If you explain to me what to do I can very well accomplished the mission.
Thanks
Old Dec 12, 2006 | 08:31 PM
firebird_1252's Avatar
i'd swap out the coolent temp switch and the fan relay. hey they arent THAT expensive and relitivly easy to do. (note to self need a new relay in the gn [sm=headbang.gif] )
gmartinez93
May 11, 2015 10:45 PM
NYGiantsfan
Aug 15, 2013 07:43 PM
jhbasse
Jan 15, 2013 06:39 PM
zyon555
May 24, 2011 11:44 AM
moby1154
May 20, 2011 05:23 PM
