Engine Cover Noise
RE: Engine Cover Noise
Engine coverrattles and it is felt in the passenger compartment and the console vibrates at times along with it. Had my wife is in the car with it in Drive running and I was able to to pinpoint the rattle to the engine cover.
ORIGINAL: bonang
My console rattles, only started when I installed the exhaust. DO you have a aftermarket exhaust?
Maybe remove the engine cover, casue the cover is not casuing the vibration.
ORIGINAL: 24_48Fan
I definitely know the engine cover is rattling because when I physically hold it with my hands it goes away with the car it drive.
ORIGINAL: 24_48Fan
I get this part "when I physically hold it with my hands it goes away". Your outside of the car with the hood up and you press down the engine cover the rattle stops. Check.
"With the car it drive" Here is where I'm lost. Maybe it is something simple as "in drive" as that colaborates with your second post so I'm going to run with that.
Ok, first are you putting alot of pressure on the cover to get it to stop vibrating or just lightly touching it.
If it is just touchin it, you probably just needto tighten something down or add in a spacer to give the cover a more snug fit. Look for areas where it might be rubbing - you will see distinct marks where there really shouldn't beany, scratches,or off coloring where paint has been scraping.
If you need to put alot of pressure, you probably need a rubber gasket added somewhere which will allow you to tighten it down harder and loose some of the hard contacts.
Sorry, carpel tunnel makes it difficult to type pain free. My wife has the car in drive and slightly turns the wheel and I hear the rattle. I put light hand pressure on it and the rattle goes away. What mounts the cover to top of the engine? Once it warms up thenI will take a look.
Thanks.
Thanks.
One loose motor mount and the whole car will resonate the rattle.
Did you jack on the engine when you did the exhaust work?
If the engine is loose. Whatever is loose on the engine is sure to be rattling or vibrating. That this happens with the car in gear leads me to believe you have a Motor Mount that needs to be overhauled ... or, replaced!
