Engine bogs down during acceleration.
Old Mar 8, 2012 | 12:33 PM
superrod29's Avatar
Angry Engine bogs down during acceleration.
Definitely need help with this one haha. Every once and a while, when Im accelerating at any speed, as i press on the gas to move from a complete stop, the engine seems like it is struggling to pull the car down the road. But once up to higher speeds it seems to be fine. Im thinking it might be the torque converter? I only put 93 octave in this card quite frequently put Lucas injection cleaner so it can't be the fuel system, and it wouldn't make sense if ignition was the problem because it still fires correctly, Im purchasing a new air filter today and hopefully that fixes the problem. Im driving from Syracuse to Rochester tomorrow so i need this fixed tonight hahaha. Thanks for reading!
Old Mar 8, 2012 | 12:41 PM
Mike 00LS's Avatar
Are you tuned for 93? If not the fuel won't fully ignite (you'll have raw fuel passing through the system) dirtying things up. Your cat could be clogged as well.
Easy way to check and/or eliminate your cat as a problem would be to start the car and let it warm up for 10-15 minutes (until it reaches closed loop) crawl under and look at the cat - if it's a redish/cherry red tint, possibly with a glow it's clogged.
Old Mar 8, 2012 | 12:43 PM
You probably ruined your catalytic converter. You are using an octane that does not ignite at the correct time, thus you have extra unburnt fuel in your system, this ruins your Cat.
Put the recommended 87 octane in from now on.
*edit* since we posted the same thing lol. To test the cat, it's not just running your car and looking, you have to run your car aggressively and then look at night to see a redness.
Old Mar 8, 2012 | 12:50 PM
BlackRainSS's Avatar
So not to interject on your thread or anything, but my car when I got it shortly after had a clogged cat. Could that have been from running lower than 91 octance by the previous owner? Just wondered the problem is fixed now but it was just a thought.
Old Mar 8, 2012 | 01:02 PM
I wouldn't say it was from using the wrong gas, as lower octane would just detonate a little early and cause knock and less power.
But anything, from dirty sensors to a poor tune could richen the fuel and help ruin the cat.
Old Mar 8, 2012 | 02:05 PM
Ok cool I was just wondering
Old Mar 8, 2012 | 03:34 PM
monte07's Avatar
not to steal this thread or any thing has a tune up and fluid change has been done on it as well. alot of times really dirty trans fluid. also worn out plugs i did my dads plugs he said the same thing he never changed them it has 120k on them and there was no electrode what i mean is the tip wich makes the spark to the meatel tip the electrod part not meatle one was shot
Old Mar 8, 2012 | 10:15 PM
superrod29's Avatar
i definitely, religously tune my car up lol. spark plugs and wires, i have iridiums and what not. just got a new CAI filter and i think it may of helped it? for now its ok but will be looking for the glowing cat once the snow is gone lol
blades3001
May 16, 2020 12:32 PM
benz86
Apr 30, 2014 07:10 AM
nicks_monte
Apr 4, 2014 11:56 AM
MonteLSV6
Aug 21, 2013 01:33 PM
2004MonteCarl
Oct 12, 2011 03:02 PM
