opinions of cam
Old Feb 23, 2012 | 12:49 PM
gasman's Avatar
Default opinions of cam
well i finally decided to step up with the big boys or somewhat. instead of the modded rockers i'm getting the vs cam with a 3.4 pully anyone else have this simmilar set up how does it feel. and yes i've done everything else all the basic boltons
Old Feb 25, 2012 | 10:41 AM
gasman's Avatar
nobody knows huh??
Old Feb 25, 2012 | 11:27 AM
zipper's Avatar
I think you should go with an XP cam instead. On average, people make more whp with the XP cam then with the VS cam.
Old Feb 25, 2012 | 01:17 PM
02on20s's Avatar
i have a xp cam on my monte along with a gen v, n* tb, speed daddy headers, 42.5 injectors, and am currently running a 3.4 pulley and put down 279 to the wheels with a moderate tune not agressive at all. i love the xp cam my power curve was gorgeous and the torque curve was like a table
Old Feb 27, 2012 | 02:45 AM
Zeke's Avatar
@gasman: Get ahold of Crower & get yourself a sick @$$ bumpstick ... Bar none.
Old Feb 27, 2012 | 08:52 AM
gasman's Avatar
but the vs cam give you more tourque though
Old Feb 27, 2012 | 12:09 PM
Zeke's Avatar
Well, you certainly want torque if you are doin' it a 1/4-mile at a time.
Old Feb 27, 2012 | 03:15 PM
gasman's Avatar
is the xp a good cam for a daily drive too?
Old Feb 27, 2012 | 03:22 PM
The VS cam is an aggressive version of the stock cam.
The XP cam will help a lot with KR, you might actually be able to run a smaller pulley if you have other supporting mods. But the low-end does go a little, so daily driving might feel a tad worse than the VS cam.
Old Feb 27, 2012 | 04:15 PM
zipper's Avatar
I wouldn't worry about a cam being bad for a daily driver unless it's an all out race cam. There are LOTS of guys running XP cams as daily drivers. You'll be fine with it.
