egr removal?
Old Nov 15, 2010 | 12:21 AM
bama_z34's Avatar
Default egr removal?
what would happen if i removed my egr on my 96 monte? it has the dohc LQ1
Old Nov 15, 2010 | 01:12 AM
Enzo354's Avatar
STILL SLOW
Your engine bay would look better. Thats it though.
Old Nov 15, 2010 | 01:44 AM
bama_z34's Avatar
would it affect my gas mileage/horsepower in any way? or affect my driveability
Old Nov 15, 2010 | 04:23 PM
Enzo354's Avatar
STILL SLOW
I think gas mileage goes down mabye 1-2 mpg. Good luck trying to get the block off plates on though, ugh.
Old Nov 15, 2010 | 05:31 PM
zipper's Avatar
Enzo's right. You will make the engine bay look better, there will be no gain in hp, and you might lose 1-2mpg. Realistically people remove their egr valve to make the engine bay look better. And I suppose the weight of your car would go down a pound or two
Old Nov 15, 2010 | 07:05 PM
I guess the big question is- why are you asking? If you think you'll gain power by removing it- you won't (assuming your system is functioning properly and isn't leaking)- it closes at WOT and idle anyways.
If you think you'll gain gas mileage; you won't do that either. Sending a relatively inert gas mixture (along with some excess unburnt fuel from incomplete combustion) back into the cylinders means the engine doesn't need as much new fuel- saving you gas. Removing EGR will hurt your part throttle fuel economy (I lost about 2-3 MPG city on my GTP).
Only real benefit I see is aesthetics/weight on a show/drag car, and keeping the engine's inside a little cleaner (you could always run seafoam or something through regularly to keep it clean).
The other thing to think of is the pcm- you need some kind of tuner or programmed PCM to keep the code from coming on (unless you can find an EGR simulator for your engine)- otherwise you'll end up with a permanent SES light.
Old Nov 15, 2010 | 10:36 PM
bama_z34's Avatar
thanks. reason i was asking is bc my mother has a gmc jimmy with a 4.3 vortec and it acutally ran better without it. but idk.
Old Nov 15, 2010 | 11:00 PM
Budsjlm's Avatar
it was probably not working corectly thuse removal made it run beter
Old Nov 15, 2010 | 11:09 PM
bama_z34's Avatar
never thought of that >_< now i feel dumb lol
BeachBumMike
Mar 3, 2008 06:03 AM
dustybird3
Feb 5, 2008 08:18 PM
gonsailin
Dec 3, 2007 03:40 PM
96Carlo
Nov 26, 2006 03:04 PM
DiscoStu
Feb 15, 2005 10:55 PM
