Egine Noise While Accelerating!
Old Jul 23, 2009 | 08:21 PM
MonteDriver's Avatar
if the sound goes away then its related to something attached to the belt
Old Jul 23, 2009 | 08:29 PM
rgant_19's Avatar
The sound goes away only when I am sitting idle at the light or while my car is parked. Which the car is ON!It only sounds when I accelerate
Old Jul 23, 2009 | 08:31 PM
did it go away with the AC turned on? I'm trying to isolate it to parts of the motor/trans
Old Jul 23, 2009 | 08:33 PM
rgant_19's Avatar
Nope! I tried everything but nah, while the AC was on, the sound was still there. Even when the HEAT was on, it still does that.
Old Jul 23, 2009 | 08:39 PM
Whats the tranny fluid look like? and any change in shifting stiffness, or shifting under acceleration?
Old Jul 23, 2009 | 08:44 PM
rgant_19's Avatar
the gears seems to change just fine. i have checked the fluid level in the trans. i will do that. but does the trans effect the way the engine sounds?
Old Jul 23, 2009 | 08:56 PM
no was wondering if you were getting tranny whine, its a sign of age.
I'll ask more Q's when i get another spark of inspiration
Old Jul 23, 2009 | 11:56 PM
rgant_19's Avatar
I just came back in the house, the sound is getting louder and louder when I drive (hear it well from the inside but from the outside, I don't know). It sounds like my whell is rubbing up against the whell cover (while in motion) which its not.
Old Jul 24, 2009 | 08:43 AM
Could be a wheel bearing then. Which would make you change the whole hub assembly on the faulty tire.
Do you feel any vibrations if you turn hard?
Old Jul 24, 2009 | 01:57 PM
rgant_19's Avatar
Don't fault me for this but you just turned on a light bulb in my head because I remember my car sounding like b4 and it was my right hub assembly. Which I had that replace but couldn't afford to get them both replaced.
