Edelbrock Carb problems
Old Feb 5, 2010 | 04:16 PM
wottreng33's Avatar
Default Edelbrock Carb problems
I got an 84 monte carlo with a gen 1 355 built pretty good and an eddie avs carb on top. The carb works really good except when i mash on it real quick the engine seems to die then a second later picks up like a bat out of hell and goes. Why does this happen? I know holley have the power valve but im not sure what edelbrocks have.
Old Feb 5, 2010 | 04:37 PM
Budsjlm's Avatar
not sure if edlbrocks have em either but accelerator pump
Old Feb 5, 2010 | 04:57 PM
70monte1's Avatar
That is why I don't like the Edelbrock Performer carbs. I have two almost new ones that have sitting on my shelf for over 10 years because of off idle bogs or when I would get on it. I think if you go to Edelbrock's site, they have some info on different problems with the carbs.
Wayne
Old Feb 5, 2010 | 08:33 PM
skylark65's Avatar
i remember hearing from someone that they disliked edelbrock carbs because most were built from almost the same design as the carter, which was mostly used on mopar muscle cars and were notorius for problems. the carter was also used on the '65-'66 buick GS with the 401ci engine, and had the same problem with bogging down under hard accereration and around tight cornering.
sounds like the problem you are having, perhaps you could find some info relating to the carter carbs & problems they had it would apply to your edelbrock? good luck figuring it out... although i would probibly spring for a re-mann'd holly....
Old Feb 6, 2010 | 10:04 PM
wottreng33's Avatar
ya im going to get a holley for my project and donate the eddie for another project but i think its so weird that it has ****ty acceleration.
Old Feb 6, 2010 | 10:26 PM
Bitchnbobb's Avatar
Come on you guys, all I got is Edelbrock carbs. Im glad I kept my original quadrajet carb lol.
Old Feb 7, 2010 | 12:12 AM
Budsjlm's Avatar
yeah ive got an eddie myself... i'll make it work till i can get a holly
Old Feb 7, 2010 | 02:22 AM
Wilco's Avatar
Those Edelbrock/Carter carbs suffer from air leaks at their base due to improper gasket placement/bad gaskets. I had a Carter 4bb that gave me fits on a 350 due to leaky gaskets and the problem never went away completely.
Old Feb 7, 2010 | 10:21 AM
wottreng33's Avatar
dang i wish i knew this before i dropped the money for an eddie.
85ssmonte355
Apr 22, 2015 02:44 PM
MySS
Feb 5, 2013 09:33 AM
cheebah
Jun 10, 2012 10:11 AM
countryboy07
Dec 29, 2007 11:29 PM
