dual snorkel air cleaners
Old Jan 30, 2006 | 03:35 AM
76MonteMan's Avatar
Default dual snorkel air cleaners
I have a question for those who would know more about performance (air flow/cool air intake) than myself. Would a dual snorkel air cleaner assembly w/ the intake hoses (http://www.montecarloss.com/images/KevinS85SS7.jpg), a K&N filter and K&N filter top OEM replacement lid (http://store.summitracing.com/largei...rt=KNN-66-1201) be more beneficial than just the K&N air cleaner assembly itself? Wouldn't having a dual snorkel air cleaner be like a K&N cool air intake system? Wouldn't having the dual snorkels w/ the hoses mounted to the core support push more cool air into the carb? Am I just delosional, lol?
Old Feb 6, 2006 | 05:59 AM
z34phoenix's Avatar
Default RE: dual snorkel air cleaners
ok. that dual snorkel system works like a cold air intake on injected cars. it's design is aimed at shielding the filter from engine heat and bringing in cold/cooler air.
if you use one of those toper's. you will allow warm air into the engine. although, you will have the potential for more air intake, but warm air is bad. i wouls go for that dual snorkel system, or....
i would get or make a cowl style intake on the hood and build a shaker style hood heat shield to isolate the air cleaner and direct the air from the cowl intake to the air cleaner. in this setup, you could use that toper and K&N... hope that makes sence to you.
Old Feb 22, 2006 | 08:13 PM
87 TToppedAerocoupe's Avatar
just trying to clarify, because I think you are onto something that i might try on my 87. Do you mean something like the old cobras used to have? where you lift up the hood and the intake is gasketed so that when you close the hood all youre getting is air drawn in from your scoop? Im not sure if thats what a shaker style hood is...just an idea...
alex
Old Mar 3, 2006 | 05:19 AM
z34phoenix's Avatar
well yeah a shaker hood would have a complete cutout thru the hood, but its kinda like what i think it would take... just like you said to seal against the hood like the old muscle cars
Old Mar 27, 2009 | 06:27 AM
iaqdix's Avatar
Yeah a dual snorkel system works like a cold air intake on injected cars...
_________________
Trion Air Bear
Old Mar 27, 2009 | 07:20 AM
drewskie043's Avatar
yes, i would go for the dual snorkel system on your monte. i would keep the top on the air cleaner assembly to keep out all the hot air. two snorkels is better than one! plus, it would be a cheaper/less work than a shaker hood. however, a shaker style setup on a monte would look bad a$$ for sure. depends on how much time/money you wanna spend on it. let us know what you end up doing!
Old Mar 30, 2009 | 10:06 PM
ChucksMonte's Avatar
try www.ramairbox.com they sell sets just like the dual snorkel ones. They are expensive, but nice kits.
STUMPMI
74
Jun 2, 2013 11:31 AM
BlackRainSS
Apr 25, 2012 08:19 PM
NoCommet
Oct 1, 2011 03:14 PM
drewskie043
Dec 21, 2009 08:19 PM
White05LT
Nov 18, 2005 10:03 AM
