does ANYONE have a 2000 with a tuner/programmer?!?!?!
Old Nov 21, 2008 | 03:08 PM
sgirl7855's Avatar
Default does ANYONE have a 2000 with a tuner/programmer?!?!?!
Hey I am tryin to find atuner or programmerfor my 2000 monte and its SO hard to find one for this year for some reason... seems only 2001- current years are all I can find.. so does ANYONE here have a 2000 SS with one?? If so, where did you get it and how much was it? Also, was is it even worth the money for the amount of power you get out of it?Thanks!!!!
Old Nov 21, 2008 | 04:46 PM
RocknSS04's Avatar
Default RE: does ANYONE have a 2000 with a chip?!?!?!
You can buy pre-programmed ECMs, or get a tuner, like from HP or Hypertech and modify the tunes. Several places offering up ECMs and tuners. ZZPerformance is the #1 source for anything performance, IMO. ZZPerformance is a GP group, but the Monte is the same engine. CALL them and talk to a tech about your needs, and order over the phone.
ZZP 1.0PCM
HP Tuners VCM Suite
3800 Performance Reprogrammed PCM
Hypertech Power Programmer III
Old Nov 22, 2008 | 10:04 AM
Powrtuner or HPTuners, both can tune your engine. They both come up for sale used all the time on clubgp.com in the classified section.
Old Nov 23, 2008 | 07:20 PM
auto_god's Avatar
You will likely find that a custom tune will provide you with the best results.
Your tuner will be able to monitor several key items such as air/fuel ratios, knock activity etc. to be able to extract the maximum performance out of your specific car/mods/fuel grade choice.
A custom tune will also allow for the transmission to be set up for your particular tastes. Shift firmness, shift points, torque convertor lock/unlock can all be fine tuned to your satisfaction. Fan on/off temps & speed limiters can be altered as well.
If you search hard enough you should be able to locate somebody local to tune your car for you, or as suggested above, you can purchase HPTuners & learn the process yourself.
Old Nov 23, 2008 | 10:10 PM
kweef's Avatar
welcome to the site to both sgirl7855 and auto god...as mentioned there are a few tuners that u can go with. if i may make a suggestion unless u are familiar with how engines work, fuel trims, tranny limits, air/fuel ratios and how each will affect ur car get a custom tuned pcm or do ALOT of research and reading before jumpin in a buying a tuner oh and hypertech is not often suggested for various reasons
Old Nov 24, 2008 | 06:52 AM
auto_god's Avatar
ORIGINAL: kweef
This is excellent advice regardless of which route you elect to go. I've seen a lot of "tunes" that just make me shake my head.As long as you stick with someone reputable, you'll be fine.
Old Nov 24, 2008 | 04:19 PM
That is a very important point- the learning curve to buying a tuner and doing it yourself is VERY steep, and you can mess up your car quite a bit if you don't know what you're doing.
On the flipside, if you plan to continue modding, it may be a wiser choice because then you aren't having to pay for a new tune every time you do a major mod.
Old Nov 24, 2008 | 04:38 PM
auto_god's Avatar
Too bad you aren't closer......I'd tune it for you!!!
Montelicious
Aug 10, 2010 06:37 PM
The Furios 1
Jul 14, 2009 10:23 PM
TonySS2007
May 6, 2009 11:42 AM
Submariner
Jul 3, 2008 01:54 PM
rcohen
Apr 26, 2007 02:14 AM
