6th Gen ('00-'05): Do I need a tune?
Old Sep 9, 2019 | 09:51 AM
Yellowprince91's Avatar
Default Do I need a tune?
When I finally install my my cai, catback exhaust system, downpipe, and catalytic converter do I need a tune or will my pcm naturally adjust to it when I reset the battery?
Old Sep 9, 2019 | 11:04 AM
If you get a P0420 code with your aftermarket catalytic, then you will need a tune, or an oxygen sensor spacer (don't always work) to shut that off.
Your car should compensate for the cold-air intake no problem. I would make sure you unplug the battery for an hour, and clean the MAF sensor during the install.
Old Sep 17, 2019 | 10:42 AM
HKnux5112's Avatar
After I did my CAI, replace my entire exhaust system, and other upgrades, I decided to go with the ZZP 3800 tune for my Monte Carlo.
I know a few people will swear against it, but I've been using it for about a year now and really enjoy what it brought. Better / quicker shifting from start, less lag basically... and deleting that code was a plus as well. Anyways, just throwing that out there.
Old Sep 17, 2019 | 11:10 AM
It doesn't look like you went with smaller supercharger pulley, or anything drastic, so the mail-order tune is fine. It's when you start getting into more boost that you want your car properly data-logged and tuned for how your car is reacting, not a canned tune. So yeah, nothing wrong with your ZZP tune!
Old Sep 25, 2019 | 10:12 AM
HKnux5112's Avatar
You would be correct, haven't changed pullys (yet). Don't think I will now since the engine is leaking oil, but thanks for the affirmation.
Yellowprince91
Sep 20, 2019 01:51 PM
07ss_ls4
13
May 9, 2014 12:17 PM
Franks 03SS
47
Oct 6, 2013 07:10 PM
Derekl21
Nov 26, 2012 08:28 AM
S.O.G.
Nov 26, 2012 12:38 AM
