DIF between a M90 Gen 3 and Gen 4???
Old Mar 3, 2007 | 06:48 PM
jfearnow's Avatar
Default DIF between a M90 Gen 3 and Gen 4???
I was wondering what is the difference between a Gen3 and Gen4 supercharger, besides $600?
[align=left] [/align]
Old Mar 5, 2007 | 03:26 AM
z34phoenix's Avatar
Default RE: DIF between a M90 Gen 3 and Gen 4???
the external housing is a little diff... not a big deal.... but the 4 gen blower outlet is much better then the 3rd gen. i have heard that a 4th gen is just as good as a ported 3rd gen!
Old Jun 5, 2007 | 09:44 PM
04 Intimidator's Avatar
Actually there is no 4th Gen. For what ever reason they skipped to GenV. The external housing looks different which will help you differentiate just at a glance. The GenIII had a bolt welded to the top to accept a nut to hold the plastic cover. The GenV doesn't have that.
Here is an end all link that will show the difference: http://www.clubgp.com/newforum/tm.as...heck=821705641
The rotors in the housing have a newer coated material that lasts longer and runs a closer tolerance. The internal housing is also smoother - not quite polished, but much closer.
The outlet port is larger and smoother than the GenIII.
Finally the LIM matches better. To swap to a GenV you need the lower intake as well, though some have been sucessful porting their own.
01 Monte SS
35
Oct 27, 2013 04:26 AM
Pure2sin
Oct 23, 2010 12:35 AM
monte07
Mar 1, 2010 12:21 PM
Wilco
Apr 5, 2009 09:26 PM
jfearnow
Mar 18, 2007 07:39 AM
