HP Dif between M90 and M112???
Old Mar 6, 2007 | 06:22 PM
jfearnow's Avatar
Default HP Dif between M90 and M112???
I am trying to find out the horsepower difference between the Eaton M90 and the M112...To see if the M112 is worth the upgrade...
Old Mar 18, 2007 | 07:39 AM
z34phoenix's Avatar
Default RE: HP Dif between M90 and M112???
HP diff is all dependent on mods. first what setup/ mods do you have?
the only real reason to swap to a m112 is if your are pushing past the efficency of the M90... and for that you would be runing something like a 2.8" pulley or smaller, full size intercooler, 50-60lb injectors, 102 plugs, headers 3.5" dp, 3" exhaust-no cat-HF muffler, custom tune via tuner, cam, springs, timing chain, possibly even ported heads!
i doubt you have all that. normally it you need an M112 you will know it. there is also the wipple charger... another option when you are considering a diff blower. but again, you have to have some very extensive mods before you even need a diff blower.
monte07
Mar 1, 2010 12:21 PM
Recluse tha Ripper
Jun 17, 2009 01:12 PM
lav74
Sep 30, 2007 10:13 AM
04 Intimidator
Aug 29, 2007 09:20 PM
jfearnow
Jun 5, 2007 09:44 PM
