delete!!!!!!!!!!!!!!
If you got what you say in your signature, then it sounds like you are pretty well set for a N/A car.
You're starting to runout of basic bolt ons, and you need to consider your long term goals. If you stick NA- its gonna be heads/cam, otherwise you're gonna have to look into a turbo, a top swap (supercharger), or bottle.
Personally, I'd do an L67 top swap- you should be able to pull it off easily for $1k, and then you open up a whole realm of mods. Just depends on if you have the skill or not.
how would i be able to pull off a top swap for a grand?
Thats $1300 with a company sourcing all the parts for you. I've seen people pull this off under $750 (gaskets/fluids included)getting the stuff on their own. Honestly the big money parts are the heads and supercharger, and neither of them are particularly expensive- most of the other stuff are parts that people sometimes practically give away. Go to www.clubgp.com/forum down to the classifieds, and get all the parts you need.
has anyone done it yet and how hard is it/ how much time will my monte be down? what kind of power am i looking at?
What its really gonna depend on is how much skill you have. If your mechanical ability ends at doing oil changes and tire rotations, you should pick something easier.
As for power, the stock L67 makes about 240 crank hp, 200 whp and 280 lb ft (I think?). You have higher compression, so you should make a pinch more than that- but it depends how much KR you're looking at when you get done. You do have a handful of mods that will help with that though.
thanks for the links and i guess that means i can get those thoughts of just quiting on the monte out of my head with my mods and the top swap what else will i need to take out a gt stang (05 and newer)?
siouxcity04montess
Aug 15, 2010 12:23 AM
