crankshaft pulley
Old Apr 14, 2008 | 03:17 PM
alkalinetri3o's Avatar
Default crankshaft pulley
Im trying to remove the crankshaft pulley and haromic balancer on a 2000 monte carlo with a 3.8 and had a few questions. I'm thinking that the bolt on the pulley, 20+ mm, has to be taken off counter clockwise. And then using a puller the balancer will come off seperately. Cause i've tried using a 1/2 inch breaker and the bolt didn't budge. And im getting conflicting stories about how to remove them. Any input would be greatly appreciated, I tried searching for it and found one very vague answer so i just wanted to verify.
Thanks
Old Apr 14, 2008 | 04:19 PM
DEI Monte SS 04's Avatar
Default RE: crankshaft pulley
Check with GM on that model. Sometimes it is a right hand thread so you would just be making it tighter. Should not be that hard to remove the bolt.
Old Apr 14, 2008 | 04:57 PM
rysZ34's Avatar
When in doubt, try to turn it the other way...lol. Good advice DEI.
Old Apr 15, 2008 | 08:27 AM
ORIGINAL: DEI Monte SS 04
It is that hard to remove the bolt- that has to be the worst bolt in the entire car. I've removed 3 so far (all engines out of the car), and had1 nightmare one.
I hit it with PB Blaster the day before, then I had one friend sit on the block (keep in mind my engine was out- so it was more difficult) and hold a big screwdriver through a hole in the flexplate to keep the engine from turning, I pushed the socket on as hard as I could. Then I had my friend (~325 lbs) jump on the end of my 1/2" breaker bar (~24" long with another 2' of pipe slipped over the end of it). He had to jump on it about 3 or 4 times before it finally broke loose.
The other two I did weren't as bad, but they were extremely difficult as well.
Unfortunately I don't remember which way it loosens, but I'm sure it loosens the opposite way the balancer turns when the engine is running. I want to say it was normal righty tighty lefty loosey though.
Old Jun 14, 2020 | 03:18 PM
Mike McFarlin's Avatar
I just took one off last night,and many more. They loosen to the left like normal,high torque so it will be difficult.
Old Jun 14, 2020 | 10:59 PM
You know the OP hasn't signed on here in more than a decade, right?
Old Aug 18, 2020 | 12:24 AM
J7EEZ's Avatar
I’m going to work on mine soon. This is helpful.
06athena
Aug 28, 2013 06:38 PM
erik2282
Apr 27, 2009 04:32 PM
motivation2k3
Sep 4, 2008 07:15 AM
alkalinetri3o
Apr 13, 2008 05:58 PM
jet404
Aug 22, 2005 12:51 AM
