crankshaft pulley
Im trying to remove the crankshaft pulley and haromic balancer on a 2000 monte carlo with a 3.8 and had a few questions. I'm thinking that the bolt on the pulley, 20+ mm, has to be taken off counter clockwise. And then using a puller the balancer will come off seperately. Cause i've tried using a 1/2 inch breaker and the bolt didn't budge. And im getting conflicting stories about how to remove them. Any input would be greatly appreciated, I tried searching for it and found one very vague answer so i just wanted to verify.
Thanks
Thanks
ORIGINAL: DEI Monte SS 04
Check with GM on that model. Sometimes it is a right hand thread so you would just be making it tighter. Should not be that hard to remove the bolt.
I hit it with PB Blaster the day before, then I had one friend sit on the block (keep in mind my engine was out- so it was more difficult) and hold a big screwdriver through a hole in the flexplate to keep the engine from turning, I pushed the socket on as hard as I could. Then I had my friend (~325 lbs) jump on the end of my 1/2" breaker bar (~24" long with another 2' of pipe slipped over the end of it). He had to jump on it about 3 or 4 times before it finally broke loose.
The other two I did weren't as bad, but they were extremely difficult as well.
Unfortunately I don't remember which way it loosens, but I'm sure it loosens the opposite way the balancer turns when the engine is running. I want to say it was normal righty tighty lefty loosey though.
It is that hard to remove the bolt- that has to be the worst bolt in the entire car. I've removed 3 so far (all engines out of the car), and had1 nightmare one.
erik2282
Apr 27, 2009 04:32 PM
motivation2k3
Sep 4, 2008 07:15 AM
alkalinetri3o
Apr 13, 2008 05:58 PM
jet404
Aug 22, 2005 12:51 AM
