Crack Top Of Cylinder Wall?
i dont even know how that would happen... i think that block may just be a paper weight now....IDK that it can be fixed...but bring it to a machine shop see what they say
my machine shop guy said that it is fixable, he said you could tap the crack and plug it, and then deck the block and you will never see it.(depends on how far down the crack goes, but you may have to sleeve it as well.)
he also said he has a 350 4 bolt main block sitting in his shop right now if you want a new one, he would come off it for $150 + shipping... (block and crank)
x2 all you need is the block, you have the rotating assembly. IMO minor cost for the piece of mind.
05montecarloyo
Aug 8, 2012 07:02 PM
