Coolant loss..
Old Sep 15, 2009 | 11:06 PM
Squeegee's Avatar
Default Coolant loss..
Have a 99 LS with the 3.1. I've replaced the intake gaskets, water pump and t-stat, and it still leaks coolant pretty bad. Iwas suggested on another forum, that it could be the coolant elbow, but when i googled, alot of stuff for the 3.8, and not the 3.1. Does the elbow exist on the 3.1?
Old Sep 16, 2009 | 07:24 AM
drewskie043's Avatar
does the coolant leak onto the ground or your just losing coolant internally? if it's internally, it could be a head gasket. if it's on the ground, is it possible you didn't seal up the water pump correctly? it's a common mistake that happens to even the best of mechanics. it's also possible the tstat cover wasn't sealed up either, or even a leaking radiator...
Old Sep 16, 2009 | 08:31 AM
Pressure test and find that leak.
Old Sep 16, 2009 | 08:38 AM
MAMONTE's Avatar
A pressure test would be the best place to start...then your not playing the guessing game. Maybe you have a crack in your radiator.
Old Sep 16, 2009 | 10:22 AM
The Popcorn King's Avatar
I dont think the 3.1 has the "ELBOW" i'll check with my book and see what i can find. You could also be leaking from your heater core. Just a thought.
Old Sep 16, 2009 | 03:34 PM
Squeegee's Avatar
Definately not the radiator and the heater core is bypassed. When I chabged the drive belt, I f-ed up and took the whole tensioner off. Is it possible it could be leaking from behind the plate that the tensioner and the water pump mount to?
Old Sep 16, 2009 | 04:30 PM
skylark65's Avatar
could be a bad hose / hoseclamp somewhere or a bad water pump, or a bad thermostat.... is it leaking onto the ground? try parking on a small tarp or peice of plastic overnight if you cannot tell.... you will be able to see about how much leaks out & where its dripping down to....
Old Sep 16, 2009 | 04:43 PM
Squeegee's Avatar
No tarp needed, exhibit a, theres no coolant pooiling around the l.i.m., its just dripping down onto the axle/sub-frame
Old Sep 16, 2009 | 05:27 PM
skylark65's Avatar
hmmmm..... you know what..... my car is having a very similar issue, driping in almost the exactly same spot, as weird as thatis, and im really only noticeing that the overflow tank is going dry, so im kinda leaning towards that leaking..... is your radiator down, or just the overflow tank?
Old Sep 16, 2009 | 06:40 PM
Squeegee's Avatar
Both actually, radiator usually goes down first though.
The Popcorn King
FWD Tech Guides '95-'07
May 26, 2008 06:31 PM
big_mecho13
Feb 14, 2008 08:17 AM
BLACK ATTACK
Jan 1, 2008 05:39 PM
lisacan2
Jan 15, 2007 12:27 AM
Matthew
Jun 19, 2005 03:25 AM
