5th Gen ('95-'99): Complete “Sure Fix” GM Intake Manifold Kit
Old Apr 16, 2012 | 05:54 PM
2003jge's Avatar
Default Complete “Sure Fix” GM Intake Manifold Kit
Hello, anyone using this Manifold? Im doing the upper/lower gaskets and was thinking might as well check into this before I start. Thanks Mike
Old Apr 16, 2012 | 08:07 PM
do you have a link?
Which vehicle/engine?
You have 2003 jge which i'm assuming is a jeff edition, but you have this thread listed as 5th gen... so pre 2000 montes.
Old Apr 17, 2012 | 09:19 AM
2003jge's Avatar
Yes it's a 2003 Jeff Gorden edition, has anyone used this manifold?
Old Apr 17, 2012 | 07:01 PM
zipper's Avatar
You need to post a link. Plus, you have a 6th gen. I have a 5th gen, lol.
Old Apr 18, 2012 | 12:02 AM
mwjames's Avatar
I just briefly looked at that, its just a refined uim. They're saying its to reduce heat on the upper end, by using aluminum lining and reducing the incoming egr pipe size. I'm not aware of having to replace the uim itself I thought it was just the gaskets? Anybody have input?
Old Apr 19, 2012 | 10:19 PM
If this is a replacement UIM, this has NO effect on LIM gaskets. If you have no known problems with your UIM, I would not replace it. Instead, replace the stove pipe that goes from the LIM into the UIM with a slightly narrow one (it comes with the Dorman UIM gasket kit).
See the stove pipe in this pic:
http://crzyz28.sytes.net/mycars/2004...e/IMG_4026.jpg
If you MUST replace your UIM, get an APN brand one (the Bonneville guys had used this when they have to replace their UIM and love it over stock):
GM Intake Manifold Kit - iNeedParts.com
KINGBASS
Apr 28, 2015 12:57 PM
Habbibie
Aug 14, 2013 05:35 PM
NYGiantsfan
Sep 6, 2012 06:03 PM
