Changing the Thermostat
Old 05-07-2011, 10:18 AM
BlownUptoHigh's Avatar
Default Changing the Thermostat
i was wondering how hard it would be to change the thermostat. when i removed the engine cover and found the place where i think the thermostat is located, it seem like it under a bunch of cables and wires. Are those easy to disconnect or move out the way so i can access the thermostat housing? Also a step by step guide would be helpful?
Also bought so far is 180 t-stat, a water gasket and socket wrench set, is that everything i need?
Old 05-07-2011, 10:35 AM
I can't give you a step by step guide, but I remember changing mine was a PITA. I have an 04, so I'm not sure how similar it is to a 99. There is a quite of bit of stuff in the way that makes the whole thing more time consuming than it should be. Once you get to the actual thermostat though, it just pops right out.
Old 05-07-2011, 11:05 PM
its two bolts, pretty simple.. check the rubber gasket and make sure u use it
Old 05-08-2011, 01:15 AM
nitehawkjcb's Avatar
Agreed
Old 05-08-2011, 02:49 PM
yeah wut about the cables and lines sitting right on top of it i cant even get to the 2nd bolt
Old 05-08-2011, 05:00 PM
Which engine is in your MC? 3.8 is child's play, 3400 is under the TB and takes a few different tools, and a 3.4 DOHC should just be left alone and burnt to the ground for insurance money. Lol
Old 05-09-2011, 12:41 AM
haha not true, wasnt that bad i owned a 97 z34 for almost 5 years
Old 05-09-2011, 09:23 AM
Move them? Use an extension?
Old 05-09-2011, 10:02 AM
i have a 3.8
there like a big double braided line covering access to the second bolt and then the fuel line is on top of that.
and i need to get another socket set for the first bolt because the screw is bigger than the second one
Old 05-09-2011, 11:47 AM
Yea, I got a 3400. It was more time consuming to change the thermostat than the radiator. LOL.
Quick Reply: Changing the Thermostat
