Changing the Thermostat
Old May 7, 2011 | 10:18 AM
BlownUptoHigh's Avatar
Default Changing the Thermostat
i was wondering how hard it would be to change the thermostat. when i removed the engine cover and found the place where i think the thermostat is located, it seem like it under a bunch of cables and wires. Are those easy to disconnect or move out the way so i can access the thermostat housing? Also a step by step guide would be helpful?
Also bought so far is 180 t-stat, a water gasket and socket wrench set, is that everything i need?
Old May 7, 2011 | 10:35 AM
coolfonz's Avatar
I can't give you a step by step guide, but I remember changing mine was a PITA. I have an 04, so I'm not sure how similar it is to a 99. There is a quite of bit of stuff in the way that makes the whole thing more time consuming than it should be. Once you get to the actual thermostat though, it just pops right out.
Old May 7, 2011 | 11:05 PM
montecarlo01ss's Avatar
its two bolts, pretty simple.. check the rubber gasket and make sure u use it
Old May 8, 2011 | 01:15 AM
nitehawkjcb's Avatar
Agreed
Old May 8, 2011 | 02:49 PM
yeah wut about the cables and lines sitting right on top of it i cant even get to the 2nd bolt
Old May 8, 2011 | 05:00 PM
Justin Knight's Avatar
Which engine is in your MC? 3.8 is child's play, 3400 is under the TB and takes a few different tools, and a 3.4 DOHC should just be left alone and burnt to the ground for insurance money. Lol
Old May 9, 2011 | 12:41 AM
haha not true, wasnt that bad i owned a 97 z34 for almost 5 years
Old May 9, 2011 | 09:23 AM
Move them? Use an extension?
Old May 9, 2011 | 10:02 AM
i have a 3.8
there like a big double braided line covering access to the second bolt and then the fuel line is on top of that.
and i need to get another socket set for the first bolt because the screw is bigger than the second one
Old May 9, 2011 | 11:47 AM
coolfonz's Avatar
Yea, I got a 3400. It was more time consuming to change the thermostat than the radiator. LOL.
