CHANGING THE SPARK PLUGS
I just got done panting the engine cover and then when i was going to put it back on i noticed that the number 4 spark plug wire had been worn away at one spot and well i need to replace it and since i am going to be doing that i was going to replace the spark plugs. so my ? is how would get to the back 3 spark plugs and is it hard to replace them? thanks for any info.
by the way i have a 2000 ss 3800 series2
RE: CHANGING THE SPARK PLUGS
I've heard from quite a few people that say you have to tilt the motor, but as Dess noted, a good combination of swivels and extensions should get the job done without going through the process of tilting the motor.
has any one tried to ge them from underneath?
I have access to a Lift so that is not a issue. just figured i would ask , I will look at it in the mornning i have to do a oil change see if i can get them that way or not
i prefer the NGK plugs but they seem to be hard to find over here in teh right side so i have to order them all the time if i want to keep up with both cars.
kool glad to know tha tit can bedone that easily
Thanks dess
Thanks dess
my reccomendation for plugs is to replace them with stock gm had them engeneered to certain standards and they seem to wook fine look how many miles you get out of a set i think ill stick with what works
