CHANGING THE SPARK PLUGS
Old Aug 30, 2006 | 09:31 PM
2000_BLACK_SS's Avatar
Default CHANGING THE SPARK PLUGS
I just got done panting the engine cover and then when i was going to put it back on i noticed that the number 4 spark plug wire had been worn away at one spot and well i need to replace it and since i am going to be doing that i was going to replace the spark plugs. so my ? is how would get to the back 3 spark plugs and is it hard to replace them? thanks for any info.
by the way i have a 2000 ss 3800 series2
Old Aug 30, 2006 | 09:39 PM
DESS03's Avatar
Default RE: CHANGING THE SPARK PLUGS
the easiest way to do this is with a 3 in extension and a swiveling spark plug socket
Old Aug 31, 2006 | 07:23 AM
Hi Luke, What plug are your going to put in ? Good Luck..
Post more pic's of your Black `Monte [:-]
`Space
[IMG]local://upfiles/714/CA07B04F1F23493FB679465EB995F271.jpg[/IMG]
Old Aug 31, 2006 | 07:39 AM
mickey's Avatar
you saying not to rock the motor forward? Man that would sure make life easier if ya didnt have to do it.
But I was told ya had to so i was dreading doing the rear three.
Old Aug 31, 2006 | 11:01 AM
montejass's Avatar
I've heard from quite a few people that say you have to tilt the motor, but as Dess noted, a good combination of swivels and extensions should get the job done without going through the process of tilting the motor.
Old Aug 31, 2006 | 01:05 PM
mickey's Avatar
has any one tried to ge them from underneath?
I have access to a Lift so that is not a issue. just figured i would ask , I will look at it in the mornning i have to do a oil change see if i can get them that way or not
Old Aug 31, 2006 | 06:00 PM
DESS03's Avatar
just using a 3 in extension and a swivel socket it only takes me a bout 30 mines to do a TUNE UP ON OUR CARS
Old Aug 31, 2006 | 07:33 PM
i am not sure what type of plugs that i want to use are there any suggestions on a good set of them
Old Aug 31, 2006 | 08:57 PM
mickey's Avatar
i prefer the NGK plugs but they seem to be hard to find over here in teh right side so i have to order them all the time if i want to keep up with both cars.
kool glad to know tha tit can bedone that easily
Thanks dess
Old Aug 31, 2006 | 09:20 PM
DESS03's Avatar
my reccomendation for plugs is to replace them with stock gm had them engeneered to certain standards and they seem to wook fine look how many miles you get out of a set i think ill stick with what works
