changed my plugs and wires... new problem!!
Old Feb 18, 2010 | 09:24 AM
Default changed my plugs and wires... new problem!!
well i changed em out and now it feels like its kind of skipping a spark or something. it happens when im running at a constant speed and only so often but when it does it happens 3 or 4 times. sombody please help its driving my nuts!!!!!
Old Feb 18, 2010 | 09:25 AM
If you are mis-firing your check engine light will flash.
Old Feb 18, 2010 | 09:27 AM
Cowboy6622's Avatar
Make sure all the plugs are tight and the wires are all the way on.. you should feel them pop a little bit as they slide on and lock in place. Since that happened right after you changed the plugs, I'm going to have to say something is loose. Happy hunting!
Old Feb 18, 2010 | 09:49 AM
MAMONTE's Avatar
Yea, if it happened RIGHT after installing new plugs, I would guess a wire or something did not get pushed down all the way.
But if the problems been there for a while, and just did not go away with new plugs and wires, I would say it sounds like a bad ignition coil.
Old Feb 18, 2010 | 01:35 PM
If it never happened before you did plugs and wires- then you need to go back through, and check. Either something isn't pushed on all the way, a plug isn't gapped right, or a wire is defective and shorting somewhere. Its pretty simple though- you only replaced a few items.
Old Feb 18, 2010 | 07:44 PM
mak330's Avatar
did you replace one wire at a time? check your firing order , if your missing there should deffinatly be a flashing CEL on your dash. Maybe try running some injector cleaner. those need maintaned too you know.
Old Feb 19, 2010 | 02:58 PM
monte07's Avatar
i had the same problem after my plug and wire change it ended up being my coil pack i didnt noticed it at first but after the plug and wire change it became noticable. it probably is the coil pack but first check the wires and the gap befro the coil replacemment. it could be some thing simple at firsti didnt gel a cel light till a week later after taking it to the dealer saing there is a problem can you run a diognostic
Old Feb 27, 2010 | 09:12 AM
well i got my coil pack tested and its not that, so my next quetion is could it be my egr getting clogged up?
iMuf
13
Jun 5, 2013 07:09 PM
Furder2010
Jun 29, 2011 10:01 PM
musicmanlott
Mar 20, 2011 12:48 PM
wht02monte
Feb 18, 2010 09:21 AM
ChevyMan2008
Mar 15, 2008 05:39 AM
