Cardone Select front axles
Old Jan 15, 2012 | 08:38 AM
jasonsmith's Avatar
Default Cardone Select front axles
Has anyone used Cardone Select front axles? I noticed yellow grease being slung all around on the passenger side. Grease on the tensioner, rack and all around. So, I figure the inner boot on the axle must be slinging the grease. So, I was looking at replacing that axle before the bearings fail from lack of grease with a new Cardone Select axle. But wanted to check to see if anyone had any problems with this brand of axle?
Old Jan 16, 2012 | 08:24 PM
mwjames's Avatar
I would take a closer look, it could be ripped. If they're not on all the way they'll sling tranny fluid but that's not yellow.
Old Jan 17, 2012 | 02:29 AM
jasonsmith's Avatar
I couldn't see if the boot was ripped. But the yellow grease being slung on the tensioner lines right up with the inner boot. So that's the only thing I can see that would sling yellow grease everywhere. So, I'll just replace the axle when it warms up some.
Old Jan 17, 2012 | 06:19 AM
They do make a replacement boot kit if the axle isn't bad. They are about 20 to 30 dollars depending on the quality.
Old Jan 17, 2012 | 06:24 AM
jasonsmith's Avatar
Yeah, but might as well spend an extra $20 and save time by just replacing the axle since it will have to come off anyways.
Old Jan 17, 2012 | 06:44 AM
I think you can replace the boot without removing the axle. They have a split in them. Replacing the axle is the best option tho for sure.
Old Jan 31, 2012 | 09:24 PM
jasonsmith's Avatar
Does transmission fluid normally dump out the transmission when you pull the axle out? The fluid kept coming out until I got the new axle in. The axle was hard to get in the transmission. I had the outer part of the axle in the hub. Then grabbed the steering knuckle/caliper, and kept slamming it towards the transmission. And finally the inner part of the axle clicked into place inside the transmission.
I had watched a few videos of the axle being replaced on front wheel drive cars and didn't see any transmission fluid come out.
The only odd thing I noticed is the brake pedal now pulses when braking like a rotor is warped. The only thing I can think of is maybe it has something to do with the alignment. Not sure if you have to get an alignment check after replacing a front axle.
Old Jan 31, 2012 | 11:51 PM
mwjames's Avatar
i replaced my axles, the tranny fluid can come out of there. its up to you for the alignment, mine seemed fine so i didnt take it back.
Old Feb 1, 2012 | 01:39 AM
Sliver's Avatar
You should check the tranny fluid to see if it is low after this change, not worth the gamble. If it is not leaking after the axle change then I wouldn't worry about, just top off to bring to the correct level. The pulsing of the breaks could be some filth that got pressed between the rotor and hub causing it to be off set. I would double check everything, especially if the brakes were fine before.
02turbomonte
Oct 17, 2013 11:37 AM
bumpin96monte
Sep 13, 2013 10:57 AM
rwolf15241
Feb 15, 2013 07:59 PM
l0gitech87
Nov 26, 2010 02:17 AM
reevesjoe
Jun 14, 2008 11:01 PM
