Car Wont Start
Old Sep 28, 2010 | 01:07 AM
Kensei's Avatar
Exclamation Car Wont Start
I have an 85 Monte Carlo LS that wont start. Now I'm a pretty good mechanic and I have an idea of what happened but I want opinions incase I'm wrong. I have 3/4 tank of gas, so I know it's not that. It worked fine yesterday but I got home from work and today I went to start it but it just cranked, didnt start. It was raining out, which I had a problem with a Corvette that when it rained it wouldnt start because of the starter. And I do hear what sounds like arching. Also I sprayed some WD-40 in the carb to try and get it to start, still nothing.
Old Sep 28, 2010 | 01:26 AM
nitehawkjcb's Avatar
Is it making a grinding noise? If not, it's probably not your starter. Check the fuel pressure.
Old Sep 28, 2010 | 09:04 PM
mooke46's Avatar
sounds more like its from the spark end of the starting process. sounds like you might be getting moisture under the distributor cap
Old Sep 28, 2010 | 09:10 PM
mooke46's Avatar
Unhappy 02 monte want continue to run
i replaced the radio and changed the ignition. i programed the ignition. it turns over and runs for a second and then stalls. there is no security light on. what could be the problem?
Old Sep 28, 2010 | 09:14 PM
MillerMonteSS's Avatar
2010 Monte Of The Year
mooke46, it is considered bad etiquette to ask questions about your car inside another persons post. I understand that you are having a problem with your 2002. Maybe you should start a new thread so that others may help you.
Kensai, why did you use WD-40? Do you think that you aren't getting fuel?
Old Sep 28, 2010 | 09:19 PM
mooke46's Avatar
sorry it wasnt done intentionally
schoentges16
Feb 27, 2021 06:43 AM
bigdomvegas
Oct 21, 2017 07:54 PM
BrandonStebing
Jul 25, 2014 11:03 AM
Knightwolf702
May 14, 2014 07:13 PM
midnitetill6
Jul 6, 2005 06:35 PM
