Can I add a traction control switch to my LS
Old 02-28-2010, 03:29 PM
Jordanshedd5's Avatar
Default Can I add a traction control switch to my LS
I have a 2000 LS and i was wondering if it was possible to add a traction control button switch like the SS have. i had the center console top piece replaced and the new one was out of an SS and has the TC button, but im not sure if there is a plug in my wiring harness for it to connect to, or if the PCM will even register it. Any ideas?
Thanks
Old 02-28-2010, 03:48 PM
lo, belive me when i say that it causes more problems that its worth. most owners disable it every time they start there engines. id sell you mine if i knew how to take it off.
Old 03-01-2010, 12:09 PM
i have an LS... i dont have a button to turn it off... Turning it off is what im wanting to do. And i think i need the button to do that.
Old 03-01-2010, 01:04 PM
the switch for the traction controlls for the 06 07 it part of the headlight switch i am not sure if the traction controlls is the same for you gen
Old 03-01-2010, 03:44 PM
Just because you add the button won't mean you have traction control. I doubt the rest of the parts are in place to have this function. You could probably add it but it would be cheaper to find a car with it installed.
Old 03-01-2010, 03:47 PM
Do you have traction control to start with that you can turn it off?
Old 03-01-2010, 04:30 PM
i see a traction control light up area on my speedo but its never been on, did they maybe not come with it?
and i read somewhere that you can never completely turn off the traction control
Old 03-01-2010, 06:16 PM
Enzo354's Avatar
STILL SLOW
TC is dumb. Id give you mine, but I use it everytime I start my car.... well not now actually.
Old 03-01-2010, 09:01 PM
could someone please explain to me the benefits of having it off verses having it on? I have mine on all the time, should I not use it all the time?? please let me know, thanks
Old 03-01-2010, 09:08 PM
When you press the button traction control won't activate, even the system normally would in the given situation. The switch deactivates the possibility that it'll turn on.
Quick Reply: Can I add a traction control switch to my LS
