Broken gas gauge!!
Old Oct 16, 2011 | 05:30 AM
Gemar's Avatar
Default Broken gas gauge!!
I have a 2001 Monte ss. The gas gauge does show when theres gas In but it just stays at full. And right before it's empty it will jump to E. I'm Itching my head over here. also my computer says everything that could be wrong with it is wrong but it's not. I'm thinking this might be it but I'm not sure. How to reset or clear errors. So I can fix my gas gauge. Thanks
Old Oct 16, 2011 | 10:31 AM
bblackstone's Avatar
Default sending unit
Have you checked the sending unit? My 2001 OPC did some thing of the same. Replaced the sending unit. Problem fixed.
Old Oct 16, 2011 | 06:20 PM
Gemar's Avatar
Your talking about the fuel level sending unit? No haven't tried that but thanks I'll get one tomorrow
Old Oct 19, 2011 | 10:19 PM
MC3point5WAX's Avatar
My Monte does the same thing.. Let me know what yu do or did to get that fixed.. It'd be really niceto have a working gas gauge.. thanks bro..
Old Oct 19, 2011 | 10:34 PM
Boxman420's Avatar
its the fuel sending unit. its easy to change out. theres a access panel in the trunk under the carpet.
Old Nov 15, 2011 | 09:14 AM
SupersportSteve's Avatar
Isn't there a shrader valve to release the fuel pressure near the fuel rail?
Old Nov 15, 2011 | 09:32 AM
There is one, should be near the front valve cover, usually has a little black cap over it that you need to remove first.
ladybridgeport
May 29, 2020 08:20 AM
kweef
May 9, 2011 08:58 PM
iMSeRiOuS
Jun 21, 2010 09:08 PM
phal
Jul 21, 2008 08:41 AM
BeachBumMike
Jul 30, 2007 11:53 AM
