Broken cat bolt(s)
Old Oct 25, 2012 | 02:49 PM
dave11's Avatar
Default Broken cat bolt(s)
I'm changing the bad cat on my '02 3.8 SS. Despite many cycles with the torch, PB Blaster, and even the old wax trick, (and despite the car having never seen snow), I broke one of the two bolts at the rear converter flange.
Is it worth buying a stud extractor, or is that unlikely to remove the rusty looking leftover end of the bolt? I don't have one, never needed one so far, but I'd buy one if it might work.
Is the only other option to drill and re-tap?
Also, haven't started on the front bolts yet, but they sure look like they're in a bad place to break a bolt. Does anyone know if they're less likely to break?
Thanks.
Old Oct 25, 2012 | 04:08 PM
03SSLE's Avatar
It sounds like you've tried a lot of the same tricks I would have used. At this point I think I'd drill it out for the largest size extractor I could. Then I'd heat it up and give it a good soaking of penetrating oil. After it completely cooled I'd give it a healthy swing from a BFH, then use the extractor. If it doesn't break free after that drilling/tapping may be the only choice.
twfurst
Aug 27, 2012 01:03 PM
04 Intimidator
Oct 19, 2011 10:42 PM
kicker
Apr 2, 2011 09:41 AM
Gr4v3_7
Oct 7, 2007 04:18 PM
fever42
Nov 1, 2005 09:58 PM
