Blinkers don't work
Old Jul 19, 2007 | 12:03 PM
joesumrall's Avatar
Default Blinkers don't work
My car has electrical issues. 02 monte carlo ss the main focus right now is the blinkers.They just recently stopped working one day but will cut on and off as I hit bumps and such. Does these cars have a flasher still and if so where is it?
Old Jul 19, 2007 | 12:17 PM
scc24540's Avatar
Default RE: Blinkers don't work
remove your glovebox, i think thats where it is on your car, if not i apoligise in advance
Old Jul 19, 2007 | 12:26 PM
wiz kidd's Avatar
its either where the glove box is or its near the steering column (this is where i usually find them)
that sounds like the problem to me is your flasher
Old Jul 19, 2007 | 12:53 PM
Mrrench's Avatar
Yep it sounds like the flasher is sticking
You can look in the owners manual and that should tell you where the flasher is located
Old Jul 19, 2007 | 07:42 PM
TrickRacin's Avatar
the flasher is in the hazzard switch. I had the same issue, changed that and it cured it. To get ya by, when they qquit just hit the hazzards on and off really quick and they will work again.
69z28rsss
Apr 19, 2012 07:26 PM
Feb 14, 2012 05:02 AM
irulesoha
Jul 9, 2010 09:49 AM
NovaSS369
Jun 21, 2010 08:05 AM
A Ny St8 of M1nd
Apr 1, 2009 09:20 AM
