'96 z34 trannys acting funny please help
Old Jul 19, 2010 | 09:03 PM
layten69's Avatar
Default '96 z34 trannys acting funny please help
I have a 1996 z34 and when i go to drive it it wont shift into gear. i get in, start it shift in gear (drive or reverse same problem), and nothing happens, the only way it works is if i rev it up wile in gear then it will shift into gear. after that i have no problems it dosent slip or anything. and i can park it and shift back into gear with no problem aslong as its still warm, but once it cools down i have the same problem. dose anyone know what this could be?
Old Jul 19, 2010 | 09:55 PM
WTF?? Thats the damnest thing Ive heard today?? IDK if this is worth anything, but there is a lever that is controlled by a button/switch thing when you hit the brakes. The lever is a tiny little thing that will allow the gearshift to move about. All I can think of is, check out that whole "system" and hope that helps?
Old Jul 20, 2010 | 12:35 AM
nitehawkjcb's Avatar
The transmission's probably going bad. Check your fluid, change the filter - it may help. If not... You'll need a new transmission. Mine on the 3100 went out that exact way - put it in gear, nothing. Rev up, bang into gear, and head on my way with no other problems.
Old Jul 20, 2010 | 07:52 AM
MAMONTE's Avatar
Sounds like the tranny is starting to go. You may be able to drive it for a while as is, but start saving for a new transmission.
Old Jul 20, 2010 | 11:10 AM
layten69's Avatar
after i rev it up it shifts into gear just fine theres no bang noise, i was thinking it could be something electrical?? or maybe a vacume leak??
Old Jul 20, 2010 | 01:42 PM
It's probably not electrical. Either A) You're low on fluid/fluid is old/filter is dirty or B) The transmission is going bad.
muleys99
Aug 19, 2015 07:43 PM
Franks 03SS
Sep 5, 2011 10:43 PM
sorcier11
Dec 31, 2008 11:14 AM
kingsblend
Apr 1, 2008 08:23 PM
01BlkSS
Dec 28, 2006 03:53 AM
