'86 upper radiator hose keeps sucking flat?
Old Aug 7, 2010 | 12:07 PM
reaper18769's Avatar
Default '86 upper radiator hose keeps sucking flat?
My upper radiator hose keeps sucking flat? I even had a new radiator put in when the new engine was, bout 6 months ago, I also replaced the hose about a week ago, someone said something about a spring in the tube, when I took off the old one their was nothing
Old Aug 7, 2010 | 12:36 PM
Hi Reaper, ~> i Hope the below link helps in some way or gives you some idea on what to look for...Good Luck 4-Sure...
Also check back to see what our expert tech member's post/suggest.....
Repair Radiator Hose: How to Repair a Radiator Hose Collapse ...
When you are confronted by a radiator hose collapse, then you may find that the upper part is completely flat, as though it has been sucked into the rest of ...
www.doityourself.com/.../repair-radiator-hose-how-to-repair-a-radiator-hose-collapse
Old Aug 7, 2010 | 10:05 PM
monte07's Avatar
i would replace the radiator hose first as well as the thermastat. because it sounds like the water pump is trying to suck cold fluid into the engine causing the hose to go flat. second after doing that make sure you have some dry card board or some thing under your car to make sure there is nothing is leaking out under the car.if it still doing the same thing i would asume that you have a lim leak or a major leak from the heads. if you have a chance after you do the thermostat replace and hose replace do a presure test to see if there is nothing major has faild
Old Aug 8, 2010 | 08:44 AM
hey thanks for your help guys, ill deffanetly give those options a try
Old Aug 17, 2010 | 07:01 AM
06Monte's Avatar
ok did your old hose have a spring inside it? if so you need to install it in the new hose if not did it have this problem with the old hose?
Old Aug 23, 2010 | 05:08 PM
BillySS's Avatar
Your rad cap is bad. Change the cap and prob fixed.
Old Sep 7, 2010 | 09:36 AM
Dade Chevy's Avatar
i agree with monte07!
Old Sep 7, 2010 | 10:03 AM
My '84 Camaro had that problem with the lower hose. I don't recall if that hose had a spring or not, but the end result was I had a clogged radiator (so clogged we just swapped it out with a brand new one).
I know you mentioned you got a new radiator when doing an engine swap, but it still might have something wrong with the radiator.... Outside of that, I'm not sure what to check....
mattilus2121
Feb 26, 2021 10:35 AM
Blazed SS
Jul 5, 2014 01:05 AM
ecosta221
Jul 4, 2013 01:17 PM
ashleymc34
Jan 24, 2010 07:17 PM
tophhckevin
Dec 18, 2008 06:20 AM
