Opinion Needed: 7th Gen Fuel Pump & Regulator
Old May 30, 2022 | 11:34 PM
Sawyer Bokusky's Avatar
Default 7th Gen Fuel Pump & Regulator
I own an 07 with the lze 3500 ffv engine, The fuel pump is busted. Are there any pumps, and regulators that will offer more flow than stock. Would the pump and regulator from a 5.3 ls4 fit in and work properly. Thanks
Old May 31, 2022 | 11:11 AM
There's plenty of options in the aftermarket to support just about any power level you want if youre willing to put in the work to adapt it. How much power are you making?
Old May 31, 2022 | 11:23 AM
It dyno’d around 250 wheel, having trouble finding ways to make it faster. I work in a classic car shop making it easy to do the work. I don’t want to go above 325 to the crank because I don’t trust the transmission that much. What would you recommend. With the fuel pump broken, I figured a different pump and regulator would give a bit more kick, I don’t know any options for that. I am more experienced with carbs.
Edit- would I need new injectors to get the result I want? and what’s a good option for them?
Old May 31, 2022 | 03:02 PM
What mods do you have now? Im sure several of the members here could help provide suggestions.
Was it fuel pump limited when it was dyno'd / tuned?
If not, switching to a higher flow pump won't add any power. Im not sure what the limit on the stock pump is, but I'd think it would be oversized enough from the factory to hit your goals - especially a FFV pump if you're running gas.
Same goes for injectors. Unless your tuner purposefully pulled power out (say by dropping timing or dropping the shift rpm) to keep the engine from running out of fuel, then adding more injector capacity wont gain you anything. A bigger injector will just result in lower duty cycle (which isn't a bad thing), but it won't add power if the car wasn't already fuel limited.
Old Jul 4, 2022 | 10:56 AM
koladx's Avatar
This one 350KPA the one works for mercruiser is 288KPA.
Kodi nox
Father Torque
Feb 21, 2021 03:14 PM
jjsamillan
Feb 18, 2021 09:11 PM
LenC
May 16, 2017 05:29 PM
lyskor
Sep 1, 2016 11:16 PM
RedZed
Mar 29, 2010 08:50 PM
