700 r4 leak
Old Jul 17, 2012 | 05:33 PM
one bad 85's Avatar
Default 700 r4 leak
Hey guys got a 85 Monte i just installed a 700 r4 i rebuilt with a shift kit into her i have a leak on the pass side on right above the pan it only leaks after i get it hot and drive it for a bit i come home and see it drippin off the pan rail i think it might be a pan gasket issues but im not quite sure i the cooler lines once leaked but dont anymore i checked the kick down cable its tight dont seem to have any cracks in it any suggestions?
Old Jul 17, 2012 | 05:54 PM
Did you check dip stick tube seal ?
Old Jul 18, 2012 | 10:50 PM
one bad 85's Avatar
yup sure did
Old Jul 19, 2012 | 09:41 AM
I had a line leak before caused by a cross threaded line. Try a uv dye kit to trace the leak. LINK Eastwood Leak Detection Kit
OD_85'305_SS
Jan 13, 2010 09:57 AM
aw9d
13
Oct 31, 2009 07:46 PM
manny
Mar 26, 2008 06:06 PM
BeachBumMike
Mar 15, 2007 01:23 AM
