5th Gen ('95-'99): 4t65 gear ratios dont match
Have a 97 monte with a 3.4 la1, 4t65. 4t65 is from a 2001 monte ss. Harness and pcm are from a 2000 lumina. According to the web both donor cars have the same ratio. It does have a positrac unit. Whats up with codes popping up for the gear ratios not matching? Thanks
First, what are the actual codes you're getting? There may be more to this.... I may also be something different in how the trans and PCM interact at the data level....
Unsure of code number. I used a scanner at oreillys. It said "gear ratios dont match" thanks
Could the prob, my info on the gear ratios came from google, so you know how that goes. The pcm is for a large port 3100 from a 2000 lumina thanks
Thats interesting that you have the LA1 3.4 in your 97. But Mike(chibi) is right, LA1 used the 2.86:1 and the L36(3.8) would have used 3.29:1. So that sounds like your issue.
I also think that the 2000 lumina would have had the 3.29:1 transmission too, not 100% sure, but if thats the case then that would be your issue. 2.86:1 transmission with a pcm from a car running a 3.29:1
The scanner should still return the code associated with it. May want to have it rescanned.
