3800 Swap
Old Jun 1, 2007 | 02:58 PM
z34phoenix's Avatar
Default RE: 3800 Swap
hey do you have a larger pic of that car?
and personally i would skip the twin turbo idea... and go with a turbo+SC setup. [sm=badbadbad.gif]
Old Jun 1, 2007 | 04:52 PM
What's the difference between the series II and series III engine?
Old Jun 1, 2007 | 09:13 PM
HaRvArDaLe's Avatar
straight from wikipedia....
The Series III motors include many changes. The upper intake manifold is now aluminum on the naturally aspirated models. Intake ports are midly improved, 1.83" intake valves (instead of 1.80" as on Series II) and 1.52" exhaust valves were introduced in 2003 engines, just before switching to Series III. Electronic throttle control is added to all versions, as is returnless fuel injection. Stronger powdered metal sinter forged connecting rods are used in 2004+ supercharged, and 2005+ naturally aspirated engines, instead of the cast iron style from Series II engines. Emissions are also reduced. In 2005, it was the first gasoline engine in the industry to attain SULEV (Super Ultra Low Emissions Vehicle).
Also note that Series III engines are the base for any 3800 produced for the 2004 year and up. This means the same block, heads, & connecting rods apply to any remaining Series II engines made after 2004 also. The difference is that Series III engines received the new superchargers (if equipped), intake manifolds, fuel systems, and electronics.
RattPack
16
Dec 30, 2015 04:09 PM
Denarius23
Sep 17, 2014 02:18 AM
golfstud2k4
Sep 29, 2010 03:37 PM
95mclt
Sep 7, 2008 11:35 PM
HaRvArDaLe
Nov 3, 2006 08:00 AM
