350 rocket vs 350
Old Sep 27, 2007 | 01:36 AM
Fiky206's Avatar
Default RE: 350 rocket vs 350
Okay one more question I have never bought a engine is there a way to test it? or have any tips for any first buyers? I dont wanna get bopped.
Old Sep 27, 2007 | 01:53 AM
GrandPaDave's Avatar
No way to test it unless you know a person with an engine test bench.
Ask for a warranty between 7 to 30 days.
Otherwise, unless you know a good small block mechanic, caviat emptor.
The seller may think that $650 is a good core price even if both items need immediate rebuilding.
Old Sep 27, 2007 | 02:06 AM
Fiky206's Avatar
Okay if the engine isnt any good, should i just buy the 850 carb. and put it on the rocket?
Old Sep 27, 2007 | 08:54 AM
04 Intimidator's Avatar
Where is it located? That would be about right in my area in the MidWest but also considered a good deal.
Old Sep 27, 2007 | 03:22 PM
88ss408's Avatar
well there is a way to see if they run but if you are to far away to go check before you buy its not good i started motors on the floor before
but you wont have to chance any thing to bolt it to the car the crossmember for the trans if you are going with the TH400 and a 850 double pumper is kinda big if ya ask me for a stock to mild 350 i would go with a 600-650 cfm but just like the trans i would go with a TH350 or a TH700R4 but if you can get every thing for a good price put it in and see how it works !!
Old Sep 27, 2007 | 04:15 PM
Fiky206's Avatar
reply to 04 Intimidator this place is located at Eugene, OR. Im going to see what happens between the two engines and keep you guys updated, so i can get some more tips. Good looking with the tips guys
Old Sep 27, 2007 | 08:30 PM
TheFullMonte's Avatar
the carb needs to match the engine. dont jump and buy somethin you dont need. best thing to do is sit down and decidehow much horsepower youre looking forin whatever engine you decide to go with. the power your engine makes will designate what size carb you need.decide if gas mileage matters to you. what carb you use will affect that and performance directly. an example of this is.. an edelbrock carb will save you some fuel but it sacrifices a lil performance. a holley is just the opposite. it will perform but gas mileage will be less. there are many decisions to be made by yourself. if you have a plan for your engine you will save money in the end.
Old Sep 27, 2007 | 09:08 PM
Cowboy6622's Avatar
the formula for a carburetar is the (CID x Maximum RPMS)/3456 i think, look it up, its something like that (wehre are you space...)
Old Sep 30, 2007 | 08:11 PM
06MC's Avatar
That will bolt right up, Go for it the only thing you have to modify will be your spline and yoke on your driveshaft. And dump that 850 for something a little more street friendly.
BeachBumMike
Apr 15, 2015 10:30 AM
BeachBumMike
Mar 26, 2015 12:39 PM
BeachBumMike
May 21, 2014 03:51 AM
Aug 21, 2013 09:44 AM
The Beep
Apr 12, 2008 01:54 AM
