305, 350 heads on a 400
Old Jan 19, 2010 | 03:22 PM
elwood blues's Avatar
Default 305, 350 heads on a 400
hey everyone, im new here and im looking for an answer to this, i have a 400 pc without any heads, and a have a complete 350, so im wondering if the 350 heads could go on that, and if there is any modifications to make ( i can probably do myself since i am a machiniste and work in a shop ) i just never did this kind of job. if you have any tips, id really need them ! thank you .
Old Jan 19, 2010 | 03:40 PM
Wilco's Avatar
You may want to check this thread out:
http://www.gregsengine.com/350to400.htm
It gives you detail info on the process and the why for the conversion.
Old Jan 20, 2010 | 12:40 PM
TheMonteMan's Avatar
if its a 400 chevy there are supposed to be steam holes in the cylinder heads. the 350 and 305 dont have them. i wouldnt want to run the 305s heads. and the 350 heads would only be worth it if they are 2.02 1.60 valves. you would still have to machine the heads though. if its a pontiac 400 the heads off of any pontiac v8 326-455 will bolt up and work but you want to watch valve size and combustion chamber size.
elwood blues
Mar 9, 2010 07:52 AM
Bitchnbobb
Feb 7, 2010 07:34 AM
monte84
Aug 10, 2007 12:46 PM
3Gs
Apr 9, 2007 01:18 PM
