3.8 monte carlo
Old Nov 26, 2006 | 08:44 PM
88ss408's Avatar
Default 3.8 monte carlo
hey guys i just got a 84 monte carlo with a 3.8 (buick motor) and the guy that owned it before started with some mods like headers and duals aluminum intake and 4bbl carb so its a little better than stock but not alot !!! so my question is can i take the top end from a 3800 s/c FWD car to do something like the grand national(dont care about turbo's )but i would like to boost it and have it EFI so if anybody knows any thing please let me know
thanks
Old Nov 28, 2006 | 10:03 PM
04 Intimidator's Avatar
Default RE: 3.8 monte carlo
I would go the turbo version. Might be easier to install without having to worry about the upper manifold.
Old Nov 28, 2006 | 10:18 PM
z34phoenix's Avatar
im not entirely sure your G.N. block is th same as the newer 3800 block. so you might not beable to do a top end swap to the blower. your safest bet would be the turbo swap. or just drop in a new L67 supercharged engine. (l67=3800 SC) that way you have a much newer engine, the computer harness and all the goodies. it will take some work to get it to work with a manuel trany im sure. but its doable. and would be sweet!
Old Nov 29, 2006 | 11:16 AM
88ss408's Avatar
can you bolt up a 3800 FWD in to RWD car are the blocks made to use the side engine mounts???
Dovas Monte
Feb 1, 2011 01:24 PM
team monte carlo ss
Aug 11, 2008 06:02 PM
